RV.Net Open Roads Forum: Class A Motorhomes: battery draining
 > battery draining
Retiredblade
Western, Pa
Posted: 03/24/12 01:51pm Link  |  Print  |  Notify Moderator
dougrainer wrote:
In 33 years as an RV tech, I have NEVER seen an Alternator cause a drain/draw on a battery (Coach or Chassis). That said, The Alternator CANNOT cause a drain on the coach batteries at all, as the coach batteries are NEVER connected to the Alternator unless the engine is ON. Now to all on these forums, when discussing batteries the CORRECT terminology is COACH for the RV/house batteries and CHASSIS for the Engine batteries. That makes for less confusion, instead of stating "Main" batteries as some will think Main can be Coach or Chassis. You need to charge each battery bank seperatly and then take a voltage reading WITHOUT shore power connected. IF you do NOT get at least 12.6 to 12.8 volts on EACH battery(not both or all batteries in the bank interconnected) then the battery is BAD. ONE bad battery can cause the others to discharge and if ONE is bad you ALWAYS replace all batteries in the set. GOOD batteries fully charged CANNOT drain down in 2 days even the Chassis battery. ANY draw that would drain a Chassis battery in 2 days will be easy to find just by looking for a appliance on the chassis side that is on. SMALL draws will not drain a GOOD fully charged battery in 2 days. Small draws on a COACH battery bank will not drain in 2 days. Even an INVERTER on Standby will not drain Coach batteries in 2 days but an Inverter left ON will. Doug
Good info, went out today, checked the chassis batteries (2) read 12.40, both. So, I put a 1 1/2 amp battery minder on them, will let them charge a couple of days. Take a reading again, should go to 13. Then take the charger off and take reading. Let them set a few days then read again, if below 12.60 I will replace them both.
genesimmons
n.c.
Posted: 03/24/12 04:28pm Link  |  Print  |  Notify Moderator
OnaQuest wrote:
genesimmons wrote:
07 bounder/workhorse all batterys were loosing charge,after charging main batt for 2 days the voltage said 11.15 a day later on vm. so i disconected neg cable and charged direct to batt overnite. now i checked volts after an hour and it is reading 13.2? so i decided to charge house batts too with charger and and for the hell of it i probed the + on the chassis batt. terminal and - cable (not connected to batt) and got 13 plus volts? i guess it was coming from house batt ? i thought when storage swithes were off it killed all power? could the problem be with aux start button.
with switches off and main batt cable disconected and then switch on the disconnect switch the main bat inside rv gives 12+volt reading? to me it acts if emergency start switch or relay is messed up i hear a bump/click when turning aux and main disconnects on and off,but hear nothing when doing the aux start button. shouldn't i hear something when moving the aux start button?
If you were plugged into shore power at the time, then what you see would be normal operation, but if not plugged in, then your aux start/charging relay probably has it's internal contacts welded together. (a very common problem).
Print this document and you will be able to trouble shoot, and fix, the problem.
i wasn't connected to shore,i was charging the batts. one at a time and coach and main batt switches off. thats when i found power going to the chassis batt cable. i think that the aux start relay is stuck,cause with all batt. connected and on i don't hear a relay kick when i hold emergency start button in. also one 6v batt maybe going bad cause it won't reach %100 and that might be whats causing the drop in volts,but if the emergency relay was not stuck i think the chassis batt would be alright. i check volts on it (still dissconected) is at 13.1 volts almost two days after charging. thanks for the repair guide also. can the relay be fixed or does it have to be replaced?
Jim@HiTek
Gresham, OR, USA
Posted: 03/25/12 08:39am Link  |  Print  |  Notify Moderator
The AUX start solenoid is just a standard automotive solenoid. Rated for continuous duty (so a little more expensive). Not really worth repair since they're $15-$20 usually.
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Winnebago Journey, '02
Cat 330HP Diesel, 36.5', two slides.
CA Traveler
The Western States
Posted: 03/25/12 09:12am Link  |  Print  |  Notify Moderator
Battery problems can cause all kinds of unexpected problems. First step it to fully charge and then load test them.
Next remove one cable to see if the relay is the cause of the problem. If the relay which is likely a continuous duty solenoid is bad then replace it.
2009 Holiday Rambler 42 Scepter with ISL 400 Cummins
750 Watts Solar MPPT 60 Controller
2004 Honda CR-V
Bob
dougrainer
Carrolton, Texas
Posted: 03/25/12 07:24am Link  |  Print  |  Notify Moderator
rvrepairnut wrote:
A bad alternater diode that stays open( power goes both way) will draw a chassis battery dead as in starting batterys.
Possibly, but in 33 years I have NEVER seen that happen and I have worked on thousands of draws and YES, all have been found and fixed. IF that happens it is something that is so remote as to not even worry about it. But, IF all other parameters are dismissed, then disconnect the alternator.
rvrepairnut
bc
Posted: 03/24/12 04:35pm Link  |  Print  |  Notify Moderator
Jim@HiTek
Gresham, OR, USA
Posted: 03/25/12 10:40am Link  |  Print  |  Notify Moderator
Most RVs have those relays outside of the BCC. Like mine. So I can't help you. Are you sure that it isn't on a sidewall in the battery compartment?
genesimmons
n.c.
Posted: 03/25/12 10:46am Link  |  Print  |  Notify Moderator
i was going by this document in the link in posts above
they are relays outside of the box,but i thought they might be inside of it cause i could see some type of solniod in it
genesimmons
n.c.
Posted: 03/25/12 09:38am Link  |  Print  |  Notify Moderator
i opened the box that contains the relays and there is a circiut board in front, how difficult is it to remove it to get to the relay?
rvrepairnut
bc
I only have worked on cars and trucks and this was something we use to see but as u say not commen.The only reason I brought it up was because the Chassis battery is directly connected to the alternater and the coach batterys are not
 > battery draining
