RV.Net Open Roads Forum: Hauling Electric Club Car Precedent Golf Cart
 > Hauling Electric Club Car Precedent Golf Cart
TZScales
Maryland
Posted: 03/23/12 05:10pm Link  |  Print  |  Notify Moderator
Hello Everyone,
I plan on purchasing a used truck to tow behind my motorhome and want to put our golf cart in the bed of the truck. The cart's length is around 8.5 to 9 feet long and is a little less than 4 feet wide. It has a 6" lift with 22" X 11" X 10" tires (weighs in around 1000 pounds) and has the rear seat kit. Based on my research so far, I will need a long bed pickup preferably 3/4 ton. Since I will be pulling front forward into the pickup (I prefer backing in), there will be considerable weight aft of the rear axle. I may be able to close the tailgate, but do not know definitively yet. I need to also keep in mind not to exceed the GVWR of the truck and the GCWR of the motorhome.
Blueox has the tailgator which may seem to be an answer for me backing in since the tailgate will be down. See here: www.blueox.com/p-1453-tailgator.aspx
For those of you that put golf carts in the bed of your pickup similiar to my golf cart configuration and tow behind your motorhome, what setup do you have that you can share? Any advice would be appreciated.
TZS and Wife
2007 Monaco Executive Sandia IV
Cummins ISX 525 Horsepower
Allison 4000 Six Speed Transmission
Roadmaster Chassis
2006 Saturn Vue
SMI Air Force One
CREATO
Beautiful Harvey N.D.
Posted: 03/23/12 05:30pm Link  |  Print  |  Notify Moderator
At 8.5 to 9 feet long you wont be closing the end gate the weight will not affect the pickup.
I dont rent out space in my brain
mytime
Winter Snowbird-somewhere
Posted: 03/23/12 05:36pm Link  |  Print  |  Notify Moderator
I haul a EZGo, lifted in my Z-71, I have the extended Cab and the 6ft.bed, the Tail gate will lift up about 1/2 of the way, I just use the nylon jack ties to hold it in Place, the rear tires sit just inside of the bed, but that leaves the rest to hang out past the back of the bed over the tailgate. There is hardly any difference in the weight that you can tell by the drop of the spring on the truck. Works great and the MH does not even know it is there. I do not have any Pictures yet. Marvin
2007 Country Coach, Allure 470, 42',ISL Cummins 400, TV- 2011 Chevy Silverado, Blackhawk and Brakemaster.
Weathertodd221
FL
Posted: 03/23/12 05:57pm Link  |  Print  |  Notify Moderator
1000lbs is heavy for a golf cart.
BigRabbitMan
Dixon, CA
Posted: 03/23/12 08:47pm Link  |  Print  |  Notify Moderator
Not for an electric cart.
BigRabbitMan & DiamondGal
Diatomaceous Earth for health
76 FMC #1046, Gas Pusher W/Chrysler 440-I
Edelbrock MPI fuel injection, Allison 545
Toad: Red '87 4x4 Subaru Brat, '95 Honda Accord
DataStorm Satellite internet / I am here-click to see
jassrnj
Bath, PA
Posted: 03/24/12 07:41am Link  |  Print  |  Notify Moderator
If you don't need the tailgate while traveling, leave it home. They are easy to take off and on. OR take it off and put it against the back wall of the bed when your Golf Cart is in the bed. At 1000 lbs you are over the weight limit of the tailgate and should have it off when loading/unloading. The Blue Ox unit looks good, but I think your cart will fit in the 8' bed with no problems.
F350OilBurner
Central MA
Posted: 03/24/12 09:03am Link  |  Print  |  Notify Moderator
* This post was edited 10/01/12 06:03am by F350OilBurner *
2006 Ford F350 Lariat CC LB DRW
6.0 PSD w/TorqShift 4x4 4.10LSD
Airlift Airbags/SureSet Controller - Timbrens
2007 Lance 1181 - All the Options
Torklift Superhitch/Tiedowns/Fastguns
TZScales
Maryland
Posted: 03/26/12 10:15am Link  |  Print  |  Notify Moderator
Thanks to all for your feedback. This is a great forum.
