RV.Net Open Roads Forum: B10 diesel fuel at Loves in Amarillo TX?
 > B10 diesel fuel at Loves in Amarillo TX?
toban
Canada
Posted: 03/23/12 06:31pm Link  |  Print  |  Notify Moderator
I was not happy to see they were pumping this B10 or up to 10% BIO fuel the sign said of this stuff. I put in 1/2 tank and hope I don't have any problems. I go to Pilot/Flying J and have not run up against this yet there.
I hope no one has had filter problems etc? I would think if they are pumping it and the truckers are using it, it should be okay?
Comments?
Toban
rv2go
Fulltime (Knoxville, TN).... or someplace else
Posted: 03/23/12 06:38pm Link  |  Print  |  Notify Moderator
I filled up at the Flying J in Anthony, TX the other day. The pump indicated that the fuel contained up to 15% Bio. 550 miles and no problems, then filled up at a Stripes Station. Pump indicated up to 20% Bio. Only about 50 miles on this. Hoping for the best.
Winnebago Journey
TN Lic. RV 2 GO
Jeep Cherokee 4x4
www.rv2go.us
I'm here #4335
Travel Photos
tempforce
Pacific Wonderland (in the summers)
Posted: 03/23/12 07:46pm Link  |  Print  |  Notify Moderator
just carry a extra fuel filter, as bio cleans the system.
b100 makes a great hand cleaner as 100% bio is non-toxic.
most diesel run much quieter, due to the flame/burn properties of the fuel.
starts burning at a higher temp and completes burning at a lower temp compared to #2 diesel.
diesel has light aromatics in the fuel that light off quick causing more of the diesel rattle we are so used to..
several states are starting to require a percentage of bio in diesel.
i know my old ford's exhaust is so much cleaner when i use bio and the french fry smell isn't so bad...
somewhere in the texas 'lost pines'
'08' Dodge mega limo-cab, 409, kelderman rear air ride, max brake controller.
'02' 34' Holiday Rambler TT, the Gypsy Wagon.
'83' Ford Ranger with a 2.2 Diesel, little smoke
'56' F100 project truck
powderman426
ohio
Posted: 03/23/12 07:39pm Link  |  Print  |  Notify Moderator
I used the B20 by mistake when I went to Yellowstone. My Cummins loved the stuff. It has never run quieter or had more power. I can't guarantee it wont cause problems but my results were good.
Ron & Charlotte
WD8CBT since 1976
28' Prowler & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
powderman426
ohio
Posted: 03/24/12 07:33am Link  |  Print  |  Notify Moderator
I thought all diesel owners carried an extra filter. I wouldn't go around the block without one.
rgatijnet1
Posted: 03/24/12 07:44am Link  |  Print  |  Notify Moderator
If I remember right, the Ultra low sulfur(USLD) diesel was supposed to, and did, "clean" the fuel system of all debris. Since USLD has been on the market now for a few years, I would guess that all diesel MH's already have "clean" fuel systems and that bio-diesel will have no affect on a general basis. Most dirty fuel systems were cleaned, and went through the filter change procedure, a few years ago. I'm sure that there will be some individual problems creep up but I doubt if it will ultimately be the fuel to blame.
Sully2
Cincinnati
Posted: 03/24/12 07:57am Link  |  Print  |  Notify Moderator
Comments?
Toban
Im not putting that junk in my coach!
2000 Country Coach Allure; Cummins ISC 330 HP; 71/2 - 8 MPG regardless
2002 Jeep Liberty
tempforce
Posted: 03/24/12 09:35pm Link  |  Print  |  Notify Moderator
it not just the junk in the older fuels, it's the waxes which all petroleum diesel has in it. the bio will clean the wax out... think of vasoline which is a by product of petroleum.
bluwtr49
Green Valley, AZ
Posted: 03/25/12 08:09am Link  |  Print  |  Notify Moderator
If you have a Cat engine....from seminar notes:
What is Caterpillar’s position regarding bio diesel?
If you choose to operate your Caterpillar engine using bio diesel, it must meet
Caterpillar’s specifications (ASTM D6751 or DIN 51606). Bio diesel fuel has
limited storage life and contains less energy content (5 – 7 %) than regular #2
diesel. Caterpillar allows up to 30% blend of bio diesel fuel.
Dick
2000 40" DP Beaver Patriot Thunder Cat C-12 425 HP, 1550 Tq
1997 Jeep GC Limited ---toad
2008 Toyota Tundra Crew Max Limited TRD (Retired)
2009 Cougar 268 RLS ~8700 lbs road wt (Retrired)
2006 Jeep Liberty Turbo Diesel.....TV in Training
rgatijnet1
Posted: 03/25/12 08:48am Link  |  Print  |  Notify Moderator
Welcome to the wonderful world of gasoline users that also have to deal with lower fuel mileage and less storage time, with ethanol blended fuel in their toads and MH's.
