RV.Net Open Roads Forum: Truck Campers: Camper for semi??
 > Camper for semi??
blkcloud01
tn
Posted: 03/24/12 07:42am Link  |  Print  |  Notify Moderator
I have a 2005 peterbilt with a 60" sleeper, I going to pull a gooseneck with a couple of pulling trucks on it.. I am looking for suggestions for some type of camper i can put on the frame (i'm taking the 5th wheel off) I want to cut a door way in the back of the sleeper so i can walk into the living area.. I only go "camping" once a year for 3-4 days.. the rest of the time I only use to when we go to tractor pulls.. I have looked at some of the living quarters made for otr trucks but they are very expensive.. a new one is 49k and it is only 120" long.. used ones are scarce as hens teeth... Thinking of something like a Lance but the area that fits over the cab of the pickup is throwing me since my sleeper is way to tall for it to fit over.. any suggestions? thanks!
SoCalDesertRider
SanDiego, CA, USA
Posted: 03/24/12 08:13am Link  |  Print  |  Notify Moderator
You could buy a small single axle travel trailer, take the axle and suspension off, and mount the trailer's frame to the truck's frame as if it were a truck bed. You're essentially creating a heavy duty class C motorhome.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
recycler
michigan
Posted: 03/24/12 08:44am Link  |  Print  |  Notify Moderator
if you don't mind building something you could try a small refer box and build it out
* This post was edited 03/25/12 06:36am by recycler *
1968 franklin 11fk
back to my 93 cummins
scolew325
salem or.
Posted: 03/24/12 09:37am Link  |  Print  |  Notify Moderator
You can contact Pastime camper in MT. Angel OR. and thet can custom build one for you. They can build it to your specifications. My brother in-law works there and they do a nice job.
http://www.pastimemfg.com/Truck_Campers/Contact.html
Scott T. Lewis
Photog101
Garden City, Michigan
Posted: 03/24/12 09:44am Link  |  Print  |  Notify Moderator
I know that back in the 80's there were a couple of West Coast drivers that had cab-over sleepers, but they were few and far between.
Your overall height might be a problem. First, you will probably have to make a platform on the frame to get the clearance for the cab-over bed. And then how high are you gonna be at the top of the roof A/C?
As for having a walk through, you could move the water tank from its usual location just under the front window of the T/C and frame mount it to the tractor.
Also, if I was going to change the Vocation of the Petercar, I would change out the tires and rims to a smaller diameter to reduce height, along with some suspension mods. Once the 5th wheel is stripped, I would also convert from a tandem axle to a single axle and change the ring/pinion to something like a 3.3:1.
The other thing that you may want to look for is a Flatbed T/C and see if that would fit easier by adding an 8'-10' flatbed right behind the cab.
I had given this some thought to doing just what you are talking about, just before I got rid of my 1984 IHC 9370 Eagle. I had plans on mounting the T/C in a service body and then mounting the service body,with the T/C, to the frame on the tractor. Remove all tanks, the batteries and generator, from the T/C, to be relocated along the side of the tractor frame, so that I could increase storage in the camper. Unfortunately, at the time I became the primary care-giver of my parents and needed to sell off anything that was not a necessity.
Since I am no longer the care-giver for my parents, I am keeping my eyes out for a crew cab straight truck and may possible go back to that project.
Good Luck:
Combat Vietnam Veteran Support our troops for serving our great country.
1997 Veri Lite RL1200 on a '02, K3500, CC, DRW, 8.1L, Allison, 4.1 gears, Bridgestone 225/70R19.5 tires.
w250383
here
Posted: 03/24/12 09:46am Link  |  Print  |  Notify Moderator
Put a truck camper backwards up to your semi's cab. Uncle bubba ran a rig like that for years. I'd show pictures but the fire took most of them.
Professionals built the Titanic, Amatures built the Ark
SkipJ
Michigan
Posted: 03/24/12 10:42am Link  |  Print  |  Notify Moderator
Seems a lot of trouble, cost for 3-4 days a year. Must be more to it?
Skipj
1992 Airstream B-190 van
1989 Airstream 25' Excella Trailer
Outfitter Apex 9.5 Truck Camper Ford F-350 Diesel 4x4
sabconsulting
High Wycombe, UK
Posted: 03/24/12 11:40am Link  |  Print  |  Notify Moderator
Agreed, when I was into heavy military vehicles I used to see several people who would mount an old touring trailer (caravan) on the back of a flat bed truck or the front of a semi trailer. Pick an old, small touring trailer up cheap, crane it on and off at will (or build a system of jacks).
Steve.
'07 Ford Ranger XLT Supercab diesel + '91 Shadow Cruiser - Sky Cruiser 1
'92 Suzuki Samurai 4x4 1.6
'09 Fiat Panda 1.2
'10 Citroen DS3 1.6 turbo
mkirsch
Rochester, NY
Posted: 03/24/12 06:07pm Link  |  Print  |  Notify Moderator
Truck camper is not the thing to cut into the front of.
I'm thinking a short cargo box, and build out the interior as a camper.
Have you considered mounting a second condo sleeper on behind (or in place of) the existing sleeper?
2002 Chevy 3500 DRW 8.1L/Allison
2000 Palomino B1500
...and the reason why I need a DRW to haul a Palomino:
2004 United 7x14 tandem axle enclosed toy trailer
2011 PJ 8x20 7-ton deckover equipment trailer
woodhog
NS
Posted: 03/24/12 06:46pm Link  |  Print  |  Notify Moderator
Here one to compare...
2004.5 Dodge 4x4 SRW Diesel, 245/70R19.5 Michelin XDS2, Bilstein Shocks
Torklift Stable loads, BD Steering Stabilizer Bar, Superchips "TOW" Programed,Rickson 19.5 wheels
2006 8.5 Northstar Arrow Longbox 200 Watts Solar, LED lights.
12 Volt DC Fridge.
 > Camper for semi??
