RV.Net Open Roads Forum: Camp Cooks and Connoisseurs: Oatmeal...
Search only in Camp Cooks and Connoisseurs
Page of 5
jetenbu
Southeast Texas
Posted: 03/25/12 08:36am Link  |  Print  |  Notify Moderator
Could I use my rice cooker in the microwave to cook steel cut oats? Just a thought. I do not have a pressure cooker.
Jim
RV: 2012 Montana 3625RE Quad Slide SKP#108921
TV: 2004.5 Dodge Dually 3500 HD
Favorite Quote: ''Life's tough, pilgrim, and it's even tougher if you're stupid.''-- John Wayne
Warning: THIS RIG PROTECTED BY SMITH AND WESSON!
U.S. Navy Vietnam Vet 1967-1968
swtgran
Brimfield, Ohio
Posted: 03/25/12 08:46am Link  |  Print  |  Notify Moderator
Yes you can make a bunch to take.
Stirring the oats in very small amount of oil prevents spewing into vent and I have done it without oil and had on problems.
Preheat oven to 350 degrees. Spread 1 cup steel oats on cookie sheet, bake for 10 min. Shake pan a couple times for even cooking and to make sure they do not burn. I do 4 cups at a time and store in quart jar.
I make two servings of oatmeal, using 1/2 cup toasted oats.
1-3/4 cups water
1/2 tsp. coconut oil
optional:
1/2 of 3 inch stick of cinnamon
a scraping of fresh nutmeg
Melt coconut oil in bottom of pan, stir in oats, add water, bring to pressure on high heat, once under pressure, immediately turn heat to lowest setting that maintains pressure, cook for 6 minutes under pressure, remove from heat and allow to release pressure naturally.
Top as desired. I like banana, toasted walnuts, and maple syrup.
Swtgran
2007 Casita 17ft SD
2005 Toyota Tundra
Go Dogs
South of Pittsburgh, PA
Posted: 03/25/12 09:57am Link  |  Print  |  Notify Moderator
Pressure Cooker Steel Cut Oats
1/2 cup Steel Cut Oats
2 cups water
Dash of salt
Combine ingredients in pressure cooker pot, select high pressure and set 10 minutes cook time. (It took the pressure cooker 10 minutes to come up to pressure and 20 minutes for a natural pressure release after the cook time, for a total prep time of 40 minutes. A quick release is not recommended with grains.)
Top with milk, fresh or dried fruit, chopped nuts or granola, and your favorite sweetener – brown or white sugar, maple syrup, or agave syrup. This time I chose dried blueberries, strawberries, granola and brown sugar.
2 – 3 servings
SWMO
Southwest Missouri
Posted: 03/25/12 01:07pm Link  |  Print  |  Notify Moderator
I like oatmeal also, but not keen on the instant. I use them in an emergency, but that's it.
I like either thick rolled or steel cut because you can feel you're eating oats. I cook the steel cut by putting them in a vacuum bottle, 1/4 C oats to 3/4 C boiling water the night before and they are done in the morning. The thick rolled I use the same ratio but cook stove top.
I add dried apple pieces, cranberries or raisins and suger, depending on my mood.
2009 Dodge 3500 Laramie, DRW, 4X4, auto, 6.7L, B & W Companion.
Jayco Designer 34RLQS, Mor/Ryde
smile2camp
Pennsylvania
Posted: 03/25/12 02:51pm Link  |  Print  |  Notify Moderator
Gotta have the raisins stirred in when the oatmeal is done cooking. Yum!
Mody n Domy
Michigan
Posted: 04/01/12 04:36pm Link  |  Print  |  Notify Moderator
I make steel cut oats only I use natural pressed apple juice instead of water 4 to 1 ratio and slow boil for 1/2 hr. I make enough for all week after it cools I put it in an air tight bowl and keep in fridge take out and microwave with white raisins, dried cranberries and pineapple or mango.
2008 Damon Challenger 378 on Workhorse chassis, 2008 HHR panel toad.
down home
south
Posted: 04/01/12 05:30pm Link  |  Print  |  Notify Moderator
If it is food it makes a poor wall paper paste.
If it's wall paper paste it makes poor food.
The few times I tried to eat it I kept trying to find some flavor in it.
A ton of cinnamon, or twice as much strawberries and a cup full of sugar and it can be gotten down.
Grits now that's food. Just add a little saltm a little bacon, country ham and hummmm good eats.
down home
south
Posted: 04/01/12 05:54pm Link  |  Print  |  Notify Moderator
Of course I meant this in a light hearted way. Rest of the family eat it and I might but it really shoots up my glucose levels.
neil.hank202
Colorado City
Posted: 04/01/12 10:48pm Link  |  Print  |  Notify Moderator
So delicious and healthy, thanks!
SWMO
Southwest Missouri
Posted: 04/02/12 09:11am Link  |  Print  |  Notify Moderator
Down home , no heavy cream in the grits?????
Page of 5
