knuts1
Mound mn
the Rhino Flex is only $30.00 as Walmart. I usually check there before I buy something and I have found most items less there including the shipping. '
pianotuna
Regina, SK, Canada
Hi,
I use a $10 hose from Walmart. I've had one leak in 12 years--and that was because I foolishly used a high pressure water supply to try to rinse it. mea culpa.
I would love to have one that remained totally flexible at say -34 c (-30 f).
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
dqdick
Council Grove, KS
Keep the hose. If that's the only time you overspend while RVing, you'll be in the minority. On the other hand, become familiar with Tweety's, Eastern Marine, etrailer and some of the other on line suppliers. Use the forums to develop what you want and need and then go out on the net and find it. Personally I only use camping world for service on the road and parts if I need to just walk in and get something, but that's just me.
Dick and Joyce
2010 Montana 3665RE
Dodge 2500HD Maxi Cab Laramie Edition
Diego, Norm, & Bitsy
thejean
Rockies
jk31668 wrote: i have the usual square bumper/hose holder. do the fancy hoses fit into them with the big ends?
I doubt it but I'll find another place to put it and keep the oem one in the bumper.
Doug and Cassi Glass
Clifton Forge, VA
Rinse the square bumper out once in a while. Grit in there tends to wear pin holes in the sewer hose.
I lay mine in a piece of plastic gutter I carry when on the ground. When you dump and it squiggles around it's like putting a sander on it.
korbe
Northern California
FWIW, we purchased the cheapest sewer hose out there and it's on it's fourth year with no problems. We don't leave ours hooked up, it gets put away after each dump.
2004 F250 SD PSD
2004 Crossroads Cruiser CF25RS
Ron3rd
Upland, CA USA
knuts1 wrote: the Rhino Flex is only $30.00 as Walmart. I usually check there before I buy something and I have found most items less there including the shipping. '
X2, I'm getting ready to upgrade the 'ol slinky to a Rhino.
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
Ron3rd
Upland, CA USA
korbe wrote: FWIW, we purchased the cheapest sewer hose out there and it's on it's fourth year with no problems. We don't leave ours hooked up, it gets put away after each dump.
Very true, and they'll last a long time if you don't drag them on the ground.
Ron3rd
Upland, CA USA
thejean wrote: jk31668 wrote: i have the usual square bumper/hose holder. do the fancy hoses fit into them with the big ends?
We carry ours in Rubbermaid bin with all the other sewer stuff in the bed of the PU. Sliding it in and out of the bumper tends to wear out the hose and rust out the inside of the bumper.
cherrykiss3
edgerton ks
I have the Rhino from Walmart. At 1 CG the sewer hole was far enough I had to go get another section. I keep all the sewer stuff in a rubbermate tote from Walmart too.
Cherry
