RV.Net Open Roads Forum: Toy Haulers: Voltage 3950 (and probably others) SAFETY ISSUE
Search only in Toy Haulers
 > Voltage 3950 (and probably others) SAFETY ISSUE
joebedford
Jasper, Ontario
Posted: 03/24/12 10:47am Link  |  Print  |  Notify Moderator
I was checking the mountings for my front jacks because the trailer is shaking more than usual as we walk around.
I opened the propane door on the right side to check the tightness of the pinch bolts on the brackets. To my surprise the upper bolt was touching my propane tank. The paint is scratched off and there is a tiny dent in the tank. I'll probably replace the tank to be safe. I hate to think what could have happened if that bolt had punctured the tank!
CHECK YOUR TANKS!
I think somebody at the factory used a longer than stock bolt.
2011 Silverado 3500HD LTZ CCLB 6 x Michelin LTX MS2 80 psi
2011 Voltage 3950 6 x Bridgestone Duravis R250 80 psi
2004 H-D VRSCB(mine)
1996 / 2007 H-D / DFT FLHTCUI Trike(hers)
2004 Thor Dutchman 35SRV traded
2004 Dodge Ram 3500 5.9 CTD traded
McKenziek
Visalia, Ca
Posted: 03/24/12 12:30pm Link  |  Print  |  Notify Moderator
Hmmm, mine seems to be shaking more. I'll be checking that when I get home for sure. Thanks Joe, and post this over on Facebook
'11 Voltage 3900, '11 F350, '11 RZR XP900,'07 YFZ450,
Kevlar everywhere else.
Voltage Facebook Page
DuneChasers Toy Hauler Adventures
SoCalDesertRider
SanDiego, CA, USA
Posted: 03/24/12 01:28pm Link  |  Print  |  Notify Moderator
You may want to change the nuts out to locking nuts, or use Loc-Tite, or tack weld the nuts in place.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
strudeau
Livermore California
Posted: 03/24/12 01:47pm Link  |  Print  |  Notify Moderator
Great call Joe! Checked mine this morning and sure enough the right side upper bolt was up against the tank. Fortunately there was above 3/4 of thread sticking out beyond on the nut, so my sawzall was happy to fix the problem.
FYI it doesn't look like the lower bolt will be a problem on these as it sits nearer the base of the tank.
lightfoot
Cary, Illinois
Posted: 03/25/12 11:17am Link  |  Print  |  Notify Moderator
Noticed that the bolts were a little too close to the propane bottles last year. Took a 9/16 socket Removed the nut, took out the carriage bolt and put it in the other way and replaced the nut. All is well and no clearance problems. No cutting required.
USN EN2 (RET)
2012 Ford F250 SC, 6.7L Turbo Diesel
2011 Voltage 3200
'94 Honda GL1500
'00 Yamaha Venture
aarondeere
Maryland
Posted: 03/25/12 12:23pm Link  |  Print  |  Notify Moderator
They must have figured it out by the time mine was built this past February and turned them around like you did.
Aaron
Mindy
Nathaniel (5 yrs old)
Cadence (3 yrs old)
2005 F550 old puller (still used on the farm)
2010 Dodge 3500 (new puller)
2012 Voltage 3600 Epic
mpierce
Scranton, ND
Posted: 03/25/12 12:50pm Link  |  Print  |  Notify Moderator
Just checked mine out. Carriage bolts, with the threads AWAY from the tanks! Good to go!
joebedford
Jasper, Ontario
Posted: 03/25/12 02:00pm Link  |  Print  |  Notify Moderator
Just curious - does anybody else think this should be a safety recall?
