RV.Net Open Roads Forum: Tech Issues: Sewere flush valve?
 > Sewere flush valve?
ceeyahd1
Camarillo, CA
Posted: 03/24/12 04:39pm Link  |  Print  |  Notify Moderator
I noticed when I hookup the hose to the sewer flush hose connector in the side of the trailer I do not hear or see any water going into the tank or coming out it seems like it was plugged up.I traced the water line from behind the sewer flush connector to a water valve and the other side of the valve goes to the black tank to flush with water. It seems like the valve is plugged and not letting the water go through. What is the name of this valve? I called an RV parts store today and they had no idea what I was talking about.
Thanks for your help.
Old-Biscuit
Across the USA
Posted: 03/24/12 05:10pm Link  |  Print  |  Notify Moderator
Vacuum breaker, back-flow preventor, anti siphon valve......
Has it worked before?
If new, could be installed backwards........if it worked before could be plugged, stuck or failed.
If you can see it and access it........remove and inspect it.
ceeyahd1
Camarillo, CA
Posted: 03/24/12 05:48pm Link  |  Print  |  Notify Moderator
I just bought the trailer used a month ago and it never worked. if it is plugged how to unlpug?
therink
Rochester
Posted: 03/24/12 05:19pm Link  |  Print  |  Notify Moderator
If your rv is brand new, the valve was likely installed backwards at the factory compliments of Gilligan. If this is the case, the valve would need to be removed and reversed.
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5'er
2012 Silverado 3500HD, SRW,LTZ,4x4, Z71, Crew, 6.0 Gasser, 4:10 Gears, Standard bed
"These days, I have problems in areas that I used to not have areas", so life is good.
Ron3rd
Upland, CA USA
Posted: 03/24/12 05:38pm Link  |  Print  |  Notify Moderator
Very possible. You should clearly hear the water spraying in the tank.
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
ceeyahd1
Camarillo, CA
Posted: 03/24/12 06:31pm Link  |  Print  |  Notify Moderator
Found the part # it is a watts 288A and it is plumbed correctly. Do you need parts to repair if plugged or should I just buy a new one?
BrokenElbow
Valencia, CA
Posted: 03/24/12 06:33pm Link  |  Print  |  Notify Moderator
Mine didn't work when I took delivery. I had the dealer replace it under warrentee. If you can, that's the way to go. Unfortunately, the factories are known to install quite a few in backwards. Mine was. It's sometimes difficult to locate and get to the valve, I would have the dealer do it.
2011 Montana 3455, MorRyde pin box, TrailerSaver BD3 air hitch, G614 tires, 2x6volt batts, 2 x Honda 2000i, Rotochoks, 6 pnt Levelup, TST TPMS, Arvika bike rack, Voyager Semi Wireless Rear Cam, Flojet Mascerator, 2008 F350 Lariat 6.4L diesel 4x4 SB CC SRW
BrokenElbow
Valencia, CA
Posted: 03/24/12 06:36pm Link  |  Print  |  Notify Moderator
Sorry, I just saw that you bought the trailer used. If you can find out where the valve is located and can reach it easily, then you can do it yourself, otherwise you might want the dealer to do it. I don't know if they get plugged, but they do fail and are frequently installed backwards.
BrokenElbow
Valencia, CA
Posted: 03/24/12 06:38pm Link  |  Print  |  Notify Moderator
You found the part, replace it, it's inexpensive.
ceeyahd1
Camarillo, CA
Posted: 03/24/12 06:40pm Link  |  Print  |  Notify Moderator
Yes I found it behind shower wall of all places. I will order one and replace myself. Thanks for your help.
