Art Kruegel
Milwaukee
We have a 08 Big Country, 3055. Just got home from a 65k trip 'snow birding'. Noticed a lot of movement in the rear view mirror betweem pin box and front cap of the rig. While unloading the rig, noticed 'trim' & wood panel in front closet bowed. Re connected rig to the truck and the 'bow' increased. Took to my dealer, found the frame around the pin box cracked and cracks on left side frame rail under the bed room. My dealer contacted Lippert,(maker of the frame and pin box)and they were sending a 'repair kit' to be welded in place.
Now the question: Will this be 'safe' to travel with? As stated we dop 'snow bird' in the winter plus use the rig in the summer for shorter trips.
avvidclif1
Any answer you get on here will be pure speculation PERIOD.
What does Lippert say about a warranty after the mod?
Clif & Millie
Ozzie half a dog tall and 2 dogs long
2009 Ford F350 SRW CC Lariat 6.4 Diesel
2011 Crossroads Cruiser CF285RL Patriot Edition
fordsooperdooty
If you experienced harsh ride or chucking and bucking, perhaps a new king box with air ride would be of benefit to cushion the jolts and soften the harshness...to prevent a re-occurance?
5th wheel pin boxes from high end manufacturers such as MorRyde, TrailAir, Demco and Fifth Airborne act as a buffer between the tow vehicle and the trailer, reducing the impact of shock and chucking.
But at any rate, if it's repaired by a quality blacksmith/frame weld shop, it will be stronger than the original by far!
Art Kruegel
Milwaukee
Lippert says the frame is out of warenty, (more than two years old). Dealer says the same about any warenty from Heartland. Sounds to me that Lippert knows about this from other 'claims', as they said they would send a 'repair kit' consisting of bigger gusset's to be welded in place.
Art Kruegel
Milwaukee
We are having an 'Airborn' installed after repairs are done.
bfast54
Traverse City ,Mi.
Lippert has LOT'S of experience with Broken frames, pin box mounts.etc.....
Check out the threads of Broken frames.
Once the repair is done by a QUALIFIED welder.....it will indeed be stronger than the original. I would check with Heartland, maybe they and lippert will help with the repair cost.only thing you have to loose...is asking, or not asking..
2000 Ford SuperDuty F-350 Powerstroke,Dually..The Tow Monster
2000 Cardinal 27RK LX
Prodigy Brake Controller
Honda EU3000is Generator
Raytek IR temp,Garmin 1300 /GPS
Doran Pressure Pro
VU Qube Satelite
Rally's attended so far-16
My Blog
Good Sam Member
bfast54
Traverse City ,Mi.
Art Kruegel wrote: Lippert says the frame is out of warenty, (more than two years old). Dealer says the same about any warenty from Heartland. Sounds to me that Lippert knows about this from other 'claims', as they said they would send a 'repair kit' consisting of bigger gusset's to be welded in place.
I would contact Heartland factory personel yourself. And they may help persuade Lippert to assist also....It is a few year s old....but Heartland has been good to their owners...call them direct.......could not hurt.
Art Kruegel
Milwaukee
Need to correct the mileage of our trip, ent to say 6500 miles, not thousand.
Sorry.
Veebyes
Bermuda & Maryland
X2 Bfast54. Had the area around all of my springhangers refabbed on our way to Alaska last year. Much better than new now. We also have the 5th Airbourne pinbox. Better than a no air pinbox but don't think it is as nice as the Trailair which is, ironically, a Lippert product. Had a Trailair on our last trailer & it was amazing to watch that thing move.
2007 Alpenlite 34RLR
ScottG
Bothell Wa.
While you have a good welder there, have him take a look at the suspension mounts. Sometimes Lippert does a shoddy job there too.
Scott, Grace and Wesly
H0NDA eu2000i
