RV.Net Open Roads Forum: Tech Issues: Xantrex Freedom 458 Questions
 > Xantrex Freedom 458 Questions
smknf250
San Diego
Posted: 03/25/12 09:21am Link  |  Print  |  Notify Moderator
So I just purchased a new Toy Hauler that has a Xantrex Freedom 458 Inverter/Convertor installed in it. I love how fast it charges my 4 six volt batteries. My question that I can't seem to find the answer to is it seems that for the inverter portion it only works for the two outlets that the TVs are plugged into. How do I make it power more 110 outlets on battery power? I would love to make the coffee maker and a few other outlets be able to get 110 power without the generator running. Thanks for the help
2oldman
Winchester WA
Posted: 03/25/12 09:30am Link  |  Print  |  Notify Moderator
Plug your shore power cord into it.
BFL13
Victoria, BC
Posted: 03/25/12 09:48am Link  |  Print  |  Notify Moderator
Where is a receptacle for doing that?
http://boatandrvaccessories.com/81-2010-12
2003 Chev 2500HD Gas, 2003 Komfort 26FS 5er
See Profile for Equipment List
smknf250
San Diego
Posted: 03/25/12 09:44am Link  |  Print  |  Notify Moderator
Interesting....I never thought to do that. I guess just to the adapter to take it down to a 110 plug and plug it in?
2oldman
Winchester WA
Posted: 03/25/12 09:51am Link  |  Print  |  Notify Moderator
Yep.
wolfe10
Posted: 03/25/12 10:15am Link  |  Print  |  Notify Moderator
It is a little more complex than that. You would need to turn OFF the 120 VAC breaker TO the inverter.
You will also need to make sure that the breakers are off to high-amp draws such as water heater, A/C's etc or make sure that everyone in the RV knows not to turn any of them on.
Better solution is to wire inverter output to the outlets you want powered by it. This can be done back at the breaker box or at the outlets themselves.
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
2oldman
Winchester WA
Posted: 03/25/12 10:29am Link  |  Print  |  Notify Moderator
Obviously you want to turn off the charger section.
MrWizard
Traveling
Posted: 03/25/12 12:33pm Link  |  Print  |  Notify Moderator
you have some "rewiring " to do
circuit path starts at the circuit breaker power panel
goes to the inverter
passes thru the inverter ( thru built in transfer relay) to the outlets being powered
when on battery only the down stream output side has power
your other circuits in the power panel have no power
you have to discoonect them in the panel you have to run wire from the inverter back to the panel and connect to those circuits
Connected thru Verizon with HotSopt WiFi using a Samsung Galaxy Nexus
I BOUGHTthis phone
hershey
Albuquerque,(fulltime) NM, USA
Posted: 03/25/12 02:40pm Link  |  Print  |  Notify Moderator
I simply added an outlet to the one that is powered from the Xantrex and use it for the coffee pot, vacuum cleaner and any other electrical devices when necessary. .
hershey - albuquerque, nm
Someday Finally Got Here
Superman was an illegal alien.
NASCAR 14 - 99
MrWizard
Traveling
Posted: 03/25/12 05:10pm Link  |  Print  |  Notify Moderator
as long as you have a route for the wire, thru cabinets etc..
what Hershey did is probably the best idea
