RV.Net Open Roads Forum: Truck Campers: camper stands.
 > camper stands.
mike mck
phoenix
Posted: 03/25/12 10:39am Link  |  Print  |  Notify Moderator
Well I'm stumped.
Looking for stands to store the Caribou on when not on the truck. Last time just used a set up with concrete block a 3/4" plywood a a few RR ties. All stuff I had around.
Huge effective and a real PITA. I'm looking for metal saw horses or stands I can set up in minutes. Did a few searches here and on the net and came up empty. Seems everyone is building their own dollys.
I'm afraid I don't have the skills to design and build my own. Any suggestions will be appreciated. Even if just a search word. Thanks and happy travels.
Mike
Photog101
Sparta, TN
Posted: 03/25/12 11:40am Link  |  Print  |  Notify Moderator
There are several ideas on this page. Scroll down until you see them.
Truck Camper University - Tips, Tricks & Projects
Combat Vietnam Veteran Support our troops for serving our great country.
1997 Veri Lite RL1200 on a '02, K3500, CC, DRW, 8.1L, Allison, 4.1 gears, Bridgestone 225/70R19.5 tires.
WestCoast1969
Kamloops, BC
Posted: 03/25/12 12:00pm Link  |  Print  |  Notify Moderator
Mike,
I use what is called a half high scaffolding stage. Unfortunately I am out of town at the moment, but when I get home I will post some pictures. I find it easy to use and it only takes a couple of minutes to set up. It is also very sturdy and stood up to 100 km/h winds.
WestCoast1969
Edit photo's below
* This post was edited 10/11/12 04:58pm by WestCoast1969 *
2000 Ford F350 Lariat, 4wd, DRW, 7.3l, Firestone Airbags, Rancho 9000 XL shocks, front/rear Hellwig Sway Bars
2011 Northern Lite 9-6 QC
WestCoast1969
AnEv942
CA
Posted: 03/25/12 02:54pm Link  |  Print  |  Notify Moderator
I'm only aware of Torklifts kit to make stands (you supply 2X6s)
http://shop.tlcentral.com/store/pc/viewPrd.asp?idcategory=124&idproduct=842.
I dont have or have not seen these so couldnt say anything about em. Just the only ones I know of for sale. (NOTE: IN description I'm unsure about the statement saying stands should be 1" min from ground-most will tell you stands are to supliment the campers jacks with most of weight on the jacks)
Our camper projects page
mike mck
phoenix
Posted: 03/25/12 05:21pm Link  |  Print  |  Notify Moderator
Mike
First and foremost thanks for your service. Second thank you Dr. obvious. can't believe I didn't think to check the TC Univ. Got my answers and a plan.
I was born and raised in Livonia. Been in AZ since the early 80's and don't get back to Mi much. Retirement in a few years and will make a northern Mich trip first on the list.
Thanks again
Mike
WestCoast1969
Kamloops, BC
Posted: 03/25/12 11:12pm Link  |  Print  |  Notify Moderator
Mike,
Below is a link to the camper stands that I mentioned in the earlier post. If anyone would like more information on what moifications I made to make it work for myself let me know and I will do my best to explain it.
https://picasaweb.google.com/10586609527........mperStand?authkey=Gv1sRgCNn4ptqgkdDC8AE#
WestCoast1969
Budster
Mira Loma, CA
Posted: 03/25/12 11:22pm Link  |  Print  |  Notify Moderator
3/4 plywood
cut 3/4 slots
put together
place under camper
you can also put them on the bed of your truck, load the camper and take them along
Bubtoofat
SE Michigan
Posted: 03/26/12 05:48am Link  |  Print  |  Notify Moderator
mike mck wrote:
"I was born and raised in Livonia."
Hey, me too.[emoticon]
I use the same set-up as Budster using the crossed plywood. Works good and is easy to store and cheap to make.
Mike
2005 Chevy 2500HD Crew 4X4 6.0
2011 Northstar Adventurer
Hellwig Bigwig, Ride-Rites, Fastguns, KYB Monomax.
"No matter where I am, I can't help feeling I'm just a day away from where I want to be."
Jackson Browne
portscanner
Georgia
Posted: 03/26/12 07:03am Link  |  Print  |  Notify Moderator
Another vote for the crossed plywood. Have your local MegaLumber store rip the pieces for you, then use a jig saw when you get home to cut the slots.
Make sure you use exterior grade (pressure treated) wood. A few bucks more and they will last forever.
One beautiful wife
Mattie and Trooper the furcampers
2011 Dodge 3500 4x4 DRW Crew Cab 6.7 Cummins, 6 speed auto, 3.73 rear end
Torklift Stableloads, Superhitch, Torklift Tiedowns
2002 Alpenlite 1150
2015 Jeep Wrangler toad w/ ReadyBrake/Brute
Web Site
mike mck
phoenix
Posted: 03/26/12 07:14am Link  |  Print  |  Notify Moderator
Budster wrote:
3/4 plywood
cut 3/4 slots
put together
place under camper
I think These might work. Thanks for the idea.
 > camper stands.
