straycat59
Virginia
Hi,
I'm remodeling my 1989 fleetwood flair class A. I'm new at this and I'm thinking of ripping up carpet. I was wondering if I use vinyl flooring what kind do I buy and where? Thanks
Dick_B
Palos Heights, IL USA
How about self-stick squares available at any home store and/or tile store. Easy to put down and if one gets damaged easy to replace if you keep a few spares.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
rvten
Crossville,TN
Ditto
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008 Type C
Ford Flex SEL 2010
There is no B+
bugs53
Jacksonville, Fl
If you are remodeling, and have a little carpenter in you, how about putting down an expensive hardwood laminent flooring. They really look great and bring your older coach into the 21 century. The laminent can be put down over a thin foam pad that will also give you more protection from road noise. But by all means, pull out the old carpet. You will be glad you did.
Bugs
bugs53
08 Tiffen Allegro, Wrangler Shahara.2dr std, Us Gear Breaking
Mango 3speed cruisers
Cookie. Springer Spaniel
Jagtech
Sunny Southern Alberta, Canada
"Allure" vinyl flooring from Home Depot...very easy to install.
1998 Triple E F53 with 460 Ford
1995 Jeep Wrangler toad
charlysmom&dad
illinois
We tore out the carpet & put in Armstrong sheet vinyl. We left the carpet on the slides. The vinyl is definitely an improvement.
2009 Fleetwood Bounder 35H
maanpaontheroad
Rogue River
We pull up our carpet and replaced it with a Armstrong vinyl. Was happy the first year. After two winters the vinyl is compet up and carpet back down. Will be replacing with a high end burber, not the low end that the manufactures put. Our dogs even hatem the vinyl.
2007 Suncruiser 38T
2004 Rubicon
FMCA F394282
Blaster Man
charlysmom&dad wrote: We tore out the carpet & put in Armstrong sheet vinyl. We left the carpet on the slides. The vinyl is definitely an improvement.
Same here. We don't like the carpet through out, especially up by the door where it gets worn out and dirty. I'd make by the door, kitchen and table either vinyl or fake wood, and the rest carpet.
erniee
Weatherford, Texas 76086
berber carpet is continuous filament. that means when you get a snag, it will ravel. not the best material for the doghouse as the backing will show on outside edges
Ernie Ekberg, Bluebird Wanderlodge
crankshop1000
se michigan
straycat59 wrote: Hi,
How about some before,during and after photos? I have the same unit and am interested in how it goes.
