RV.Net Open Roads Forum: Toy Haulers: wheel bearings
Search only in Toy Haulers
 > wheel bearings
HTElectrical
Las Vegas
Posted: 03/25/12 10:19pm Link  |  Print  |  Notify Moderator
ScottG wrote:
Cool Canuck wrote:
lincster wrote:
Don't use bearing buddies, they will blow the rear seals out and grease will get on your brakes.
White Lithium wheel bearing grease here.
X2 -- I've seen the results.
X3. Even though I was very careful in spinning the wheel and using very little pressure, it still went past the seals.
It's a great idea but they don't work.
Than you have a problem. Bad seals, incorrect seals, etc.. because if there wasn't a problem, and you FOLLOWED the proper lubricating procedure, grease would NOT have went past the seal. Period.
2007 Duramax, Cognito 7"-9" Lift, 35" Hankooks
2009 284SA Vortex
pcassidy111
California
Posted: 03/26/12 12:01am Link  |  Print  |  Notify Moderator
For grease I use Sta-Lube SL3110. It exceeds Al-ko and Dexter's minimum specifications.
Pete
gandude
east bay
Posted: 03/27/12 10:08am Link  |  Print  |  Notify Moderator
If you just repack the bearings, it's very important to use the same base of grease currently in use. If you change the grease base, the hubs, bearings, seals and spindles need to be completely cleaned of the old grease.
mixed grease bases will 'fight' each other. Improper lubrication will result.
Tahoe 21WTB Toyhauler
06 Dodge 3500 SLT, QC, LB, 4x4, 5.9, auto 370's
03 Kawasaki 360 Prarie
03 Kawasaki 300 Bayou
79 Honda XL 250
12 Honda XR 650
Doughboy12
Minnesota
Posted: 03/27/12 10:58am Link  |  Print  |  Notify Moderator
If you pump them past full, where do you think the grease is going to go? You can't just blindly keep adding grease. They aren't magic.
sunnybrooktoyhauler
new jersey
Posted: 03/26/12 02:29pm Link  |  Print  |  Notify Moderator
Thanks guys fof the help. Happy motoring
Cool Canuck
Winnipeg, MB, Canada
Posted: 03/26/12 08:49am Link  |  Print  |  Notify Moderator
I pull my wheels at least once a year for one reason or another. The first time I did that with this trailer, I found the one of the brakes full of grease from the ez lube hub. I have no trust in them and who needs a pound of grease in the axle anyway.
The Manufacturer says to inspect once a year. I will do my bearings by hand at that point. The brakes get cleaned up and inspected. I get annal about the tires and suspension. I put on over 4,000 miles a year and do not want problems on the road.
As far as I'm concerned, those bearing buddies/ez lube should be left to boat trailers. That's just me. Each to their own.
04 Everest 343L
2011 F250 PSD CC
SOLD - 01 F250 PSD S/C S/B
SOLD - 00 Jayco 313
HTElectrical
Las Vegas
Posted: 03/27/12 11:54pm Link  |  Print  |  Notify Moderator
Easy, the old displaced grease will begin to flow back out the cap around the grease gun nozzle.
pcassidy111
California
Posted: 03/27/12 05:36pm Link  |  Print  |  Notify Moderator
If you are using a bearing buddy you are supposed to watch the springloaded plate and make sure you don't fully compress the spring. If you are using the drilled spindle (I forget the. Al-Ko trade name) you remove the spindle dust seal cap and pump grease through the zerk on the spindle. Excess grease come back out through the outer wheel bearing and all over your hand holding the hose on the zerk fitting indicating it is time to stop pumping. If you are getting grease on the shoes you probably have the wrong grease seals, they are a special double lip seal.
 > wheel bearings
