Hi, I have a 99 Coachman Mirada and Would like to replace the table. The reason why, I left a gallon of water on the table over the winter and it developed a pin hole leak, needless to say the laminate let go and the particle board swelled. The leak was not from the water jug bursting due to the cold as the RV is stored in a heated garage.
I have looked online and have not found replacement tables. Does anyone know if they are available or will I need to make one?
Thanks
Steve B
Steve B
4100 lb 8.872@ 156 MPH naturally aspirated
Square peg in a round hole is the way to go
Your local cabinet shop that does kitchen cabinets could make one easily if you are afraid to do it yourself. Just get some board the correct size and glue the lamiinate on. Edging is availabgle and you have a professional looking table top.
2003 Newmar Mountain Aire, Workhorse W22, 2008 Saturn Vue, Falcon 5250, & US Gear Unified Tow Brake
