RV.Net Open Roads Forum: Class A Motorhomes: Tire Pressure Monitors
 > Tire Pressure Monitors
Page of 7
rolnhome
Casa Grande, Az
Posted: 03/25/12 05:16pm Link  |  Print  |  Notify Moderator
How important are they to have? Are they necessary or a helpful tool?
We're in Arizona
Executive
Posted: 03/25/12 05:31pm Link  |  Print  |  Notify Moderator
Depends on who you talk to. IMHO, they are near the top of the list of important things to have. Most systems, I have TST 507, give you an up to the minute reading of tire pressure and temperature. They cycle ever 5 seconds to each tire. The Federal Government feels they're important enough to require them as mandatory equipment beginning with the 2013 models. You could check your tire pressure each time you stop like we used to do but having that info immediately is pretty important. Before a blow out, oftentimes a tire will heat up rapidly, the TPMS hopefully would sound a warning to allow you to stop before that occurred. They may seem expensive but what price do you put on safety...???....Dennis
THE WORLD IS CHANGED BY YOUR EXAMPLE, NOT BY YOUR OPINIONS
Dennis and Debi Ninth Year Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
kpmacaz
Mesa,AZ,USA
Posted: 03/25/12 05:34pm Link  |  Print  |  Notify Moderator
I had the external valve stem versions to start with and they caused more trouble then they were worth. I have switched to the internal versions and a range extender that I plug into the front of the trailer. My tow vehicle has TPM covering its tires and the extra one covering all trailer tires and both spare tires. I did have a blow out in NM on the trailer and I did not know it at first and fellow travelers on the interstate had to let me know. That one experience made me get them and it helps my sense of safety.
2007 Jayco 25RKS and 2006 GMC Yukon
bugs53
Jacksonville, Fl
Posted: 03/25/12 05:44pm Link  |  Print  |  Notify Moderator
I have never used them. I do check my tires each morning of a trip and pay close attention to tire pressure. We travel with several coaches who have them and there always seems to some kind of problem with them.
Bugs
bugs53
08 Tiffen Allegro, Wrangler Shahara.2dr std, Us Gear Breaking
Mango 3speed cruisers
Cookie. Springer Spaniel
Dutch_12078
Winters south, summers north
Posted: 03/25/12 05:57pm Link  |  Print  |  Notify Moderator
My 10 sensor TST 510 system has alerted me to both tire and brake problems on my toad that could have been very expensive had they gone unnoticed. In four years of service, I have not had any issues with any part of the system.
Dutch
2001 GBM Landau 34' Class A
Alpenliter
Fulltimer: Wherever we are!
Posted: 03/25/12 06:24pm Link  |  Print  |  Notify Moderator
While not necessary they are convenient. Instead of crawling around my rig before each trio checking my tire pressures, I push a button and read the information for each tire. It has alerted me to a problem on two occasions, possibly preventing damage to my rig.
My first Wife Linda, 45+years 2004 F-450 CC, DRW 6.0 Classy Chassis Upgrade Bulletproof Diesel upgrades 1997 33' Alpenlite 400 Watts Solar Lifetime Good Sam Member #39644174 Escapees SKP#89882 Vietnam Vet '67-'68 [
Note: Due to invalid formatting, all formatting has been ignored.
peaches&cream
Northwest Georgia
Posted: 03/25/12 06:31pm Link  |  Print  |  Notify Moderator
They can be very easily replaced with a good gauge and a IR reader. Then you can stop every 5 miles and check the temps and pressure. You get the same thing as a TPMS [emoticon]
lanerd
Home in Ridgecrest CA for the winter.
Say you're going down the highway at the speed limit enjoying the scenery and lovin' your free lifestyle. You checked the tire pressure of all 10 of your tires before starting out and feel very confident that they are all in great shape.
Unfortunately, and unknown to you, you're inner right dual just picked up a large nail (or something) that punctured the tire and is allowing it to deflate very gradually and will eventually lose all of its air and will, in all probably, break its bead on the rim and then will start to flop around. It will then very quickly, and literally, come apart wrapping around whatever is within its reach. Brake lines, hydraulic hoses, electrical cables, fiberglass, wheel well covers, ect will not be any match for the destructive power of that tire.
You can well imagine what kind of damage that tire could cause and how big a bite out of your wallet it will generate.
Now don't forget that the partner to that deflating dual is now supporting all that extra weight. That, unfortunately, can damage that tire and could possibly fail at a later date.
Now if the tire exploded immediately after being punctured, chances are you may not hear or feel it (especially if it is one of the tires on your toad). You can possibly continue to travel along until somebody pulls up next to you waving frantically and honking their horn trying to get your attention. That distance you travel until someone gets you to understand what's going on will also provide sufficient amount of time for that exploded tire to do the damage mentioned above.
Of course, if you had a TPMS, it would have alerted you to the pressure loss almost immediately allowing you you safely pull over and determine the problem....saving you untold amounts of $$.
That's my story and I'm sticking to it.
Ron
Ron & Sandie
2013 Tiffin Phaeton 42LH Cummins ISL 400hp
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified by U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Allegro
RETIRED!! How sweet it is....
Ivylog
Blairsville, GA and WPB, FL.
Posted: 03/25/12 06:58pm Link  |  Print  |  Notify Moderator
Bought mine more for the toad than the MH as no way to know what's going on back there even though I used a IR temp gun at every stop.
04 Monaco Dynasty 42' quad slide
How I tow.
Towing a Prius without a dolly
Where am I?
How I spend the winter.
Ozarkan
Ozarks
Posted: 03/25/12 07:02pm Link  |  Print  |  Notify Moderator
The concept sounds good. I spent over $400 on a nVision system from Hopkins Mfg. It never worked right. The company sent me two complete replacement systems and each worked worse than the previous ones. I junked the lot and am back to checking my air pressure daily.
Warren & Judy
2007 Newmar Kountry Star DP 39'
Page of 7
