blain_gatterdam
Columbus, Ohio
Currently I have a 454 chevy and 3 speed transmission p30 chassis. Is there a direct bolt in transmission from later years to add an overdrive to my motorhome? I know I could buy a new allison for a few thousand bucks, but would rather keep it simple. What transmissions from what would handle my motor and weight?
33 foot winnebago p30 454 3 speed auto
dalmationlovers
Port Orchard, WA
Blain,
I just sent you a PM for a copy of the P30 manual. Just email me back and I'll send it to you.
Arnold
Jarlaxle
New England
A good trans shop can build a TH-700R4 that will work...it will cost about $2000.
John and Elizabeth (Liz), with 3 nutty cats
My beloved St. Bernard, Marm, lost him 1/2/12
Current rig:
1992 International Genesis school bus conversion
rvrepairnut
bc
Jarlaxle wrote: A good trans shop can build a TH-700R4 that will work...it will cost about $2000.
No you want the turbo 400 style OD 4l60ed or 4l80ed
same as they used in a 1992 454 one ton chev Pickup
LVJ58
Las Vegas, Nevada
Might want to check into Gear Vendor units, but they're pretty expensive.
http://www.gearvendors.com/agmh3s.html
Good luck
Jim & Sherry Seward
Las Vegas, NV
2000 Residency 3790 V-10 w/tags & Banks System
2003 Suzuki XL/7 toad
rvrepairnut
bc
blain_gatterdam wrote: Currently I have a 454 chevy and 3 speed transmission p30 chassis. Is there a direct bolt in transmission from later years to add an overdrive to my motorhome? I know I could buy a new allison for a few thousand bucks, but would rather keep it simple. What transmissions from what would handle my motor and weight?
yes the later 4 speed overdrive 4l80ED will bolt right in.U need to buy a special electronics package to make it shift/work properly
In Fact a transmission from a little 305V8 will bolt right to any 454
and vice versa
Jarlaxle
New England
rvrepairnut wrote: Jarlaxle wrote: A good trans shop can build a TH-700R4 that will work...it will cost about $2000.
4L80E requires electronic controls. TH700 does not.
4L60E is an electronic TH700.
Mike Hohnstein
Germantown, Wi
Have a GearVendors available at a good price.www.AutoTransDesign.com
