RV.Net Open Roads Forum: Truck Campers: '90 Lance Stereo Pre-wire
 > '90 Lance Stereo Pre-wire
*BS*
NorCal
Posted: 03/25/12 08:14pm Link  |  Print  |  Notify Moderator
I have a '90 Lance 4000 9.4 camper and Im trying to figure out where the pre-wired speakers wires end up at. They dive into the wall w/ the power and ground and cant find them anywhere.
Thanks
Bryce
Don & Linda
Western PA / Cape Cod
Posted: 03/25/12 10:35pm Link  |  Print  |  Notify Moderator
Mine were taped up inside a cabinet void. Had to pull a draw and peek in with a flashlight. Mine had 12v power, ground, antenna and speaker wires all nicely wrapped together in an area for the adding of a radio. I think most mfg's did about the same thing, sometimes. Good luck, Don
Sorry if this post seems long, I lacked the time to make it shorter.
almost quote from S.L. Clemens
Don & Linda
1st RV UL EMS 4s Dome
2nd RV 21' AMF Scamper TT PV D300 Dodge
3rd RV National Seabreeze 133LX w/Demco Dolly
4th RV Jayco 2450 5TH PV Ford F-250 SD
*BS*
NorCal
Posted: 03/26/12 06:11pm Link  |  Print  |  Notify Moderator
I found the bundle w/ pwr/grd & speaker wires, but I cant find the other end of the speaker wires????????
Fishbreath
home
Posted: 03/26/12 07:47pm Link  |  Print  |  Notify Moderator
I had a 92 and one end of the bundle was underneath the refer and the speaker wires were in the overhead cabinet. If you lift up the bottom of the cabinet (it was very thin plywood, you should find them). As I recall, the bottom of the refer had a wood panel about 3 or 4 inches tall that ran the width of the refer. It was a combination of that thin plywood and thicker trim. The power bundle and extras were in there.
I am sorry but I can't recall how I found them, but I think I located them by looking through the outside access to the refer. (I think. Old age has blurred my memory)
Good luck
Bill
Don & Linda
Posted: 03/27/12 09:34pm Link  |  Print  |  Notify Moderator
Sorry, our camper, same time period 5th had speakers, factory mounted in the ceiling, but no radio.
The hard pard for us was finding the radio end of the wiring. I thought you were dealing with the same scenario.
My bad.
Lance's website offers a 1999 pfd file showing approximate speaker location, but also recommends contacting a dealer for exact location.
Try giving Lance a call at 661/949-3322
joerg68
Ueberherrn, Germany
Posted: 03/28/12 05:35am Link  |  Print  |  Notify Moderator
That is pretty bad. I think the speakers go in the ceiling.
Lancecamper.com -> support has the factory brochures back to 1999. Maybe you find some helpful pictures in there.
In our 2002 Lance there were stickers on the inside of the ceiling that indicated where the speakers would go. Two above the dinette, two in the cabover. If they did this already way back when your camper was made, you might find the places where the stickers used to be (rectangular spots with glue residue and slightly brighter than the surrounding material, about 1 x 2 in).
In our Lance there were rectangular OSB plates with round coutouts for the speakers in the roof behind the Luan. A stud finder might help finding candidate locations, or an acoustic test of the ceiling (should sound differently when you tap it).
Good luck,
Joerg
"Pickups are very handy cars. One step on the brakes, and everything you need is right behind you!"
Mulebrain
Boca Raton, FL
Posted: 03/28/12 06:51am Link  |  Print  |  Notify Moderator
Here is what I did, I just looked online for pictures of my camper that had that option installed. Walla! Looked at the picture, and sure enough all the wires are there.
