RV.Net Open Roads Forum: Tow Vehicles: Research winding down almost ready to buy
Search only in Tow Vehicles
 > Research winding down almost ready to buy
timc1207
Posted: 03/25/12 08:30pm Link  |  Print  |  Notify Moderator
Well I am almost ready to drop the hammer on a new TV. I have been researching trucks and though being a Ford guy for many years now I think I may go with a 2010 Dodge 2500 Laramie 4x4. I like what I hear about the cummins engine, the fuel tank capacity and the ease of installing delete kits for performance improvements.
I Thought I would give a shout here and see if anyone had pros/cons to add on the Dodge trucks. The truck I am looking at has 47k miles and I think it can be had for about 40k drive out. The truck is super clean and along with being fully loaded it has power steps and tonneau cover installed. I am thinking this is a decent deal for my area here in central Texas, anyone have opinions?
2008 Forest River Wildwood Le 27BHBS - 2010 Dodge 2500 Laramie Mega cab 6.7L Cummins diesel, Flo-Pro exhaust, XRT Pro tuner, Mygig Lock Pick, Access tonneau cover, Ranch Hand grill guard, KC daylighters.
donn0128
Pronounced Ore-gun
Posted: 03/25/12 09:01pm Link  |  Print  |  Notify Moderator
Make sure it has ALL of the updates done before you buy. What rear end ratio does it have? You really want the 3.73 for a good compromise between economy and towing power. Do not let it idle for extended periods of time.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
bailer6334
Prescott, AZ
Posted: 03/25/12 09:20pm Link  |  Print  |  Notify Moderator
You didn't say if it is a gasser or diesel. If diesel don't be to surprised at the poor mileage. Had a 07 3500 dually 4X4 and got 13MPG empty. However my 5.9L was great. And keep an eye on the oil level. They have a habit of adding diesel to the oil.
2011 Arctic Fox 29-5T 5th Wheel
2011 Silverado HD 3500 6.6L Duramax Diesel Crew Cab
Short Bed 4X4 SRW LT
50gal Transfer Flow Aux. Tank
16K Valley Hitch w/bed saver
4x4ord
Canada
Posted: 03/25/12 09:42pm Link  |  Print  |  Notify Moderator
Go to the Cummins forums and read up on the mileage people are getting - even deleted. If staying within your GVWR is even remotely important to you I would buy a SRW 1 ton rather than a 3/4 ton.
2011 F350 SRW short box 4x4 CC 6.7 PS King Ranch
B&W TurnoverBall and Companion
2003 Citation Supreme 34 RLTS
timc1207
Posted: 03/26/12 12:02am Link  |  Print  |  Notify Moderator
That is one of the things I will be looking at with the gearing. I had heard they do run hot but extended idling should not be an issue with me. I will mainly use t for back and fourth to work and towing my trailer.
timc1207
Posted: 03/26/12 12:05am Link  |  Print  |  Notify Moderator
Anything would be better gas mileage than my F250 V-10!
This one is the 6.7 cummins deisel.
Thanks for the info on the oil level.
timc1207
Posted: 03/26/12 12:09am Link  |  Print  |  Notify Moderator
I'm sure I will be just fine with the 3/4 ton. My TT weighs 6600 empty, loaded and I don't think I will ever get over 8000 loaded, I am usually around 7200-7500 packed up.
I have done a lot of reading on the cummins forums learning as much as I can. I also have several friends that have 3/4 and 1 ton Dodge trucks, they have been very happy with them which is something else that is luring me away from Ford.
jerem0621
Sequatchie, TN
Posted: 03/26/12 12:34am Link  |  Print  |  Notify Moderator
Sounds like an awesome truck!
One question I have.
do you intend to ever purchase a Golf Cart to haul to the campground? If so, the tongue weight, golf cart weight, plus family will quickly tax the payload of your truck.
According to this chart
Clicky
Looks like the Larime 2500 Crew Cab has about 2140 lbs payload capacity.
However, this is an awesome truck and I would be very proud to have one sitting in my drive way.
Thanks!
TT: 1995 Layton 2910
Tow Vehicle: 1999 F-350, v10, 2wd, Crew Cab, Dually
Hitch: Draw-Tite Trunnion WD Hitch
Sway Control: Valley dual friction sway control
Brake Control: Tekonsha Voyager
"It's Kind of Fun To Do The Impossible"
~Walt Disney~
timc1207
Posted: 03/26/12 01:41am Link  |  Print  |  Notify Moderator
Clicky
Thanks!
No golf cart in our future; there may be a 4 wheeler during deer season but that is muck lighter and I only hunt 90 miles from home.
Thank you and I do think it will be an awesome truck. I only have to see if the dealership and I can come to an agreement on price and trade in. I'm planning on heading over there tuesday but really can't buy until the end of the week, it will take me that long to gather funds.
nremtp143
Georgia
Posted: 03/26/12 02:18am Link  |  Print  |  Notify Moderator
I have been a Ford lover/owner for years and am really dreading the next sentence. If I were going to buy a new truck today, it would probably be a Dodge. Man, that was hard to write! The main reason being the Cummins with a proven track record. Ford and Chevy have crazy expensive fuel systems to own outside of warranty. I know that failures with these fuel systems have been rare, but getting more all the time. My FIL has a '09 Dodge 2500 4x4 Cummins which has been a good truck. Good luck with your truck, it should serve you nicely.
2012 Sandpiper 365SAQ, Goodyear G614s, TST TPMS
2010 F350 DRW 6.4L 4x4, Edge CTS, B&W Companion, Viair 10007 air system, Firestone Ride-Rites,Flo-Pro cold air pipe
2001 Excursion Limited 7.3L 4x4, V/B Springs
2001 Silverado 3500 DRW CCLB 8.1L/Allison 4x4
