RV.Net Open Roads Forum: Class A Motorhomes: No Brake Lights
 > No Brake Lights
REVY03
salt lake city
Posted: 03/26/12 07:59am Link  |  Print  |  Notify Moderator
Hello all, Great site. I have a Fleetwood Revolution 2003
My brake lights quit working,I have pulled every fuse I can find.
Any other XC chassis folks know other places to look. I looked under driver side,Battery compartment,Switched around Relays.I'm lost.
I was thinking about the Diodes under the dash-The Towing Brake controller is spliced into one of these,Problem.
Thanks,Mike
rgatijnet1
Posted: 03/26/12 08:02am Link  |  Print  |  Notify Moderator
Have you used a jumper wire to bypass the brake light switch right by the brake pedal?
mobilefleet
on the road
Posted: 03/26/12 08:28am Link  |  Print  |  Notify Moderator
one of the wires going to the brake control should come from the brake light switch, so could be bad splice or connection
workhardplayharder
Treasure Coast Florida
Posted: 03/26/12 08:29am Link  |  Print  |  Notify Moderator
Anytime I have problems with anything electrical I check the ground first.
tropical36
Southwest Florida_USA
Posted: 03/26/12 06:16pm Link  |  Print  |  Notify Moderator
Thanks,Mike
Signal and four ways working OK? Do they utilize the same bulb? Brake pedal switch needs checked and you'll probably find that it's in the ground return, so if your meter doesn't read a positive voltage, try using a jumper to find a good ground.
"We are often so caught up in our destination that we forget to appreciate the journey."
1998 36ft. National Tropi-Cal Model 6350 on a 1997 Chevy P32
Chassis_7.4 Vortec Engine_4L80E Tranny_slide_tag axle.
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
REVY03
salt lake city
Posted: 03/26/12 07:27pm Link  |  Print  |  Notify Moderator
Hello, I believe I found the problem,I bought an Electrical Tracer-needed one for work--Hooked it up to the brake wires at the air switch and went hunting.
I found the Hot wire at the junction block had broken inside the insulation. Thats why all the fuses were good-Crazy.
When I find a minute I will splice them back together and hope thats it. Will report back.
I've learned alot on this site to keep our RV going.
Thanks,Mike
REVY03
salt lake city
Posted: 03/26/12 07:31pm Link  |  Print  |  Notify Moderator
I forgot, that I read alot on here about folks following wires and thought this Tracer should maybe be in every RVs tool box.
I would never have found that broken wire without it.
Mike
royST
ann arbor
Posted: 03/26/12 08:20pm Link  |  Print  |  Notify Moderator
First thing that I do whenever it comes to the lights is to first check the bulbs themselves. It could probably be that the bulb is already worn out. Then I'd check with the electrical.
rvrepairnut
bc
Posted: 03/26/12 08:45pm Link  |  Print  |  Notify Moderator
Thanks,Mike
thats extremely rare and unusual the power feed to the brake lite fuse breaking at the connection
GPWayne
Lake Stevens. WA
Posted: 03/26/12 10:38pm Link  |  Print  |  Notify Moderator
Well done.
Can you post some info on the Tracer you used.
 > No Brake Lights
