RV.Net Open Roads Forum: Hybrid Travel Trailers: Fresh water tank specs
Open Roads Forum  >  Hybrid Travel Trailers
 > Fresh water tank specs
Tinbangertom
Ottawa, Canada
Posted: 04/01/12 11:51am Link  |  Print  |  Notify Moderator
My fav is Quinte isle campground cherry valley Picton ont on lake ontario
Tom
Laura
Kirstyn
Deanna
Grumpy Gramps
Teddy Bear
301TBS
Ontario, Canada
Posted: 04/01/12 02:34pm Link  |  Print  |  Notify Moderator
Point Farms, Pinery, Inverhuron, Macgregor Pt., all on lake Huron. Nice Provincial Parks on the water.
2012 Crossroads Z1 271B
2009 F150 4x4,4.6,3v. 6spd. 3.73/9.75
Reese dual cam
kingrick5
Canada
Posted: 04/02/12 02:07pm Link  |  Print  |  Notify Moderator
Hey Guys....Back to my electrical problem.
Recharged my battery then plugged in the shore power again. Well, before I plugged in I hooked up the battery and I immediately heard what I thought was the furnace kick on again. This is with all the breakers off!!! I looked at my indicator lights (tank levels etc.) and both water heater switches (gas and electric) were on and the water pump. I switched all three off. It wasn't the heater that was running, it was the water pump. There was, of course, no water in the tanks so, as a saftey feature,. I guess, it throws the breaker. Save the punp from burning out I suppose. Anyway.. I will be filling the tanks in the near future to flush out the antifreeze and sanitize. We'll see how the pump works then. But, I think we're good. Mystery solved.....How hard could it be???
Chuck_S
Broadview Hts, OH, USA
Posted: 04/03/12 06:39pm Link  |  Print  |  Notify Moderator
There are no breakers to trip on the 12v side. Water pump can't throw a breaker (it's 12vDC) or burn a fuse by running empty. In fact the pump isn't hurt in the least bit by running dry.
The furnace can't trip a breaker either, it's 12vDC.
Your electrical problem has transmorphed into a towing capacity thread, thanks to thread rip off -- just like you did to this thread by asking about Ontario campgrounds in the middle of a water capacity discussion.
How hard is it to start a new thread? Or search for "Ontario?"
-- Chuck
'06 Roo 23SS behind '07 Expedition out of Cleveland
Our Photo pages
kingrick5
Canada
Posted: 04/13/12 06:28am Link  |  Print  |  Notify Moderator
To rinse or not to rinse?? Newbie question. If I promise not to hold up the line at the dump station how does one rinse out the black water tank? Got our first trip planned for June (First day of summer).
bikendan
Napa, Cal.
Posted: 04/13/12 09:40am Link  |  Print  |  Notify Moderator
there are a number of ways to rinse it, but dump stations often don't have a hose that will connect.
you can install a tank rinser or use a wand-type of sprayer that you do from inside.
you could use your own hose to attach but doing this will take time.
tank rinser will be the quickest at a dump station.
Dan- Firefighter, Shawn- Musician/Entrepreneur, Zoe- Faithful Golden Retriever, 2007 Chevrolet Avalanche LS, 2007 Rockwood Roo 23SS w/Equalizer and Prodigy, and 5 Mtn. bikes and 2 Road bikes
