RV.Net Open Roads Forum: Class A Motorhomes: Jack spring removal
 > Jack spring removal
Dale.Traveling
Newport News, VA
Posted: 03/28/12 08:32pm Link  |  Print  |  Notify Moderator
Since the springs are Ok either the cylinder is binding or there is something restricting the return flow of oil. A good hydraulic shop should be able to rebuild the cylinder without much of a problem. The next potential problem I'm wondering if you have a sticking valve that is restricting the flow of oil back to the valve block. Been a while since I last helped out the missile launcher techs on my last ship so my hydraulic theory is a bit rusty.
2006 Hurricane 31D aka 'Moby' the Whale
FCC(SW) US Navy Retired 1980-2003
Stella my Navigator
Bogart the All American RV Dog
and
Cocoui waiting for me at the Rainbow Bridge
jauguston
Bellingham, WA
Posted: 03/29/12 03:00pm Link  |  Print  |  Notify Moderator
If you are swapping a old style spring with another old style spring you haven't learned much. The new style springs are stronger. You can identify the new ones by the shape of the coils on the ends. They are wound with a taper like a bee hive at the ends. The old style all the coils all the way to the ends are the same diameter.
Get a set of new style springs from HWH and a can of spray silicone and try again.
Jim
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
kansanforlife
paola ks
Posted: 03/29/12 04:45pm Link  |  Print  |  Notify Moderator
It was a new style spring on there. Somebody else put them on the rear jacks.Have tried both silicone and atf fluid. Funny thing is they worked a couple of times after i started this.
SoakedKarma
Reno neh-va-duh
Posted: 04/10/12 09:32pm Link  |  Print  |  Notify Moderator
Dale.Traveling wrote:
Use thin wood shims between each coil of the spring. Easy to do on springs still attached when the jacks are extended but will require some effort on the new springs.
Read this thread for details. This one also.
Well Y'all answered my Question... Been putting off ordering 3 sets of springs a couple of years now after replacing a broken set.. What a bear it was.. Thanks
