USMC46
I left my steps out while parked for too long..I think. They are not pulling in fully without assistance. Assuming the issue may be some rust where they are hinged, can someone advise the best lubricant that can stand up to the rain, etc. Thanks.
Jim & Carmel
http://sayreodyssey.blogspot.com/
2004 Dutch Star 41'
2006 Jeep Liberty
Blue Ox Aventa Tow Bar
Brake Buddy
rv2go
Fulltime (Knoxville, TN).... or someplace else
White lithium grease in a spray can.
Winnebago Journey
TN Lic. RV 2 GO
Jeep Cherokee 4x4
www.rv2go.us
I'm here #4335
Travel Photos
accsys
Green Cove Springs, FL
Kwikee All Purpose Kwik Lube
John & Doris
Doris and Robbies Blogs
2007 Tiffin Phaeton QDH 40 w/Cat 7 350
2004 Liberty Renegade 4x4 Toad
Roadmaster Falcon 2 tow bar
Air Force One toad braking system
FMCA F380583, PA, Good Sams
Crazy Ray
Monroe,La
NAPA Chain Lube, work for us.
RET ARMY 1980, DW Donna , "Tiny" (furkid) . Class A, 2007 Bounder 35E, Ford Chassis, 4 SAMS 6VOLTS,405W Solar,TriStar 45 Controller,1750W INVERTER, YAMAHA 2400, TOW: Honda CRV. READY BRAKE. "Living Our Dream". NASCAR FAN 14,18,20,11 LOVE CO & NM
gbopp
The Keystone State
rv2go wrote: White lithium grease in a spray can.
x2. Also, before you spray, use compressed air to blow out the dirt and rust from the joints.
kneal44
EAST CENTRAL TEXAS
in a spray can ...CHAIN LUB... ITS GOT GREASE AND MOLY.
Seeps into tight bearings and last.
second: marine bearing lub.... wont wash out.
when u play in the sand .... you can get stuck
9-24-08 corpus christi padre island texas. wrecker had to haul me out!
'92 dp 5.9 cummins 190 hp....8mpg yuck!
Jtroop1
Michigan
X3
2010 Fleetwood Encounter 32BH
Tom N
Sarver, PA/Crystal River, FL/Shelocta, PA
Kwikee lube is white lithium grease.
Walmart sells white lithium grease in a spray can for $1.69 in their auto dept.
-Tom
Sarver, PA/Crystal River, FL/Shelocta, PA · W3TLN · FMCA 335149 · Mystic Knights of the Sea
2005 Suncruiser 38R · W24 chassis, no chassis mods needed · 2012 Honda Accord EX-L · 2008 Honda Odyssey EX-L
96Bounder30E
America is my home!
I use foaming motorcycle / bicycle chain lube......one squirt a year on each pivot point keeps it moving freely......
Eric
96 Bounder 30E-F53(460)
stock Ford intake w/K&N air filter
used Thorley headers
new Banks resonator, muffler, tail pipe and 4" polished SS exhaust tip
MEXICOWANDERER
las peñas, michoacan, mexico
Molybdenum disulphide powder in aerosol form. Try Dri-Slide.
The stuff does not attract grit and dust like grease or oils, lubricates far better, and lasts ten times as long. If it's good enough for an M16 it's good enough for me :-)
