RV.Net Open Roads Forum: General RVing Issues: Pay at pump question
 > Pay at pump question
Page of 5
Homer
Northeast Indiana
Posted: 03/27/12 06:03pm Link  |  Print  |  Notify Moderator
I always call my CC company and advise them if I am going to traveling and will be using their card for gas. I have never had a pump shut off on me when I have notified them. I should also mention it is a good idea to notify them when you are back in your home territory.
gemsworld
Sunny Southern California
Posted: 03/27/12 06:29pm Link  |  Print  |  Notify Moderator
The banks and credit card issuers are the ones setting the credit limit on credit card transactions at the pump.
Charltons
Battle Ground, WA
Posted: 03/27/12 06:36pm Link  |  Print  |  Notify Moderator
My debit card does this, at $75.00. Never had an issue with credit card doing it. I have re-run my debit a couple of times though with no problems.
2012 Dodge Ram 2500 Crew Cab 4X4 TCD
2012 Keystone Sprinter 311BHS
Peg Leg
Anderson, IN
Posted: 03/27/12 06:38pm Link  |  Print  |  Notify Moderator
I had one card that had a limit of 6 or 7 uses a day. I found that stations used a 50 cent precharge to preauthorize the card, so that it showed as 2 transactions for each fill up. That night we were staying in a motel and the card was denided. A call the next morning straighted it out and doubled the charges per day allowed. Since then I carry more than one card. I also fill up at Flying J or Pilot, when possible, with an RV advantage card that allows fillups of over 100 gals without shutting off.
2012 Chevy 3500HD Dually 4X4
Crew Cab long bed 6.0 gasser 4.10
06 Hitchiker II LS 29.5 FKTS
Yamaha EF3000iSE
retired gadgetman
MTPockets1
Posted: 03/27/12 07:15pm Link  |  Print  |  Notify Moderator
I can't figure out why the fuel stops limit the amount you can pump at one time.... It's not the credit card company... I can charge up to my card limit at the department store, but only $75 or $100 at the fuel stop.... Crazy..
2012 3055RL Big Horn - Dexter 7000 lb axles - G rated LT Tires
MorRyde, Genset, Dual Panes, 2 A/C, Yeti Package
2013 F350 DRW 4x4 Crew King Ranch
D.E.Bishop
Eagle Rock, CA
Posted: 03/27/12 07:18pm Link  |  Print  |  Notify Moderator
Mountain Mamma,
This past fall we took a ten week, 13,000 mile trip from Los Angeles to PEI to Florida and back to Los Angeles. We used two credit cards and bought gas primarily from COSTCO (AE) and Sam's Club (Visa), we have a 90 gallon gas tank and there was only one time that I couldn't use my card over and over till I filled up. I don't remember where it was but somewhere in the East. I told my DW and she called the 800 number while we sat at the pump and got them to release our card so I could finish fueling. In that one case it was a regional thing with Visa.
We always notify both AE and Visa when we start out and at least once on everylong trip (more than a week in length or a thousand miles or so) we get a text message to call the CC 800 number and confirm we are still in possition of our cards. During that trip there was a gas station in Louisana that required we charge an amount prior to filling or their pumps whould shut off and reject our card. I charged $300 or something like that and when it filled went ack and they charged back the difference between what I charged and what I received.
Hope I answered your question, and I hope you understand that letting your CC companies know you wil be traveling and charging large amounts of fuel and that you will be in some far distant parts of this beautiful country.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
1990 Bounder 27D
1995 Suzuki Sidekick 4X4
Stowmaster 5000
BB_TX
McKinney, Texas
Posted: 03/27/12 08:11pm Link  |  Print  |  Notify Moderator
It is a rare case that I do not use the card twice to fill up. Most places I stop it cuts off at $99. And I usually need $10-$15 or more to finish filling it up. Has never been a problem other than the hassle of having to do it.
mosseater
Dillsburg, PA
Posted: 03/27/12 08:39pm Link  |  Print  |  Notify Moderator
Several times with our Citicard, we couldn't use it AT ALL until we called, because we were out of our "home territory". I always call before we leave and give them the general route and expected return date.
Sunset Creek 298 BH
mich800
Pontiac, MI
Posted: 03/27/12 09:12pm Link  |  Print  |  Notify Moderator
Probably because you are not signing a charge slip like in the store.
wny_pat
Western NYS
Posted: 03/27/12 09:25pm Link  |  Print  |  Notify Moderator
No, not your bank or credit card issuer, but the stations bank and credit card service does it. And they are all different, depending on the station and area you are in.
Page of 5
