phillyg
Front Royal, VA
Yep, it depends. The new Heartlands with the tapered nose side have a decal there that shows 88 degree turns possible, I assume with a short bed truck. Is 88 degrees good enough for most of us? I don't know the answer to that.
2002 Keystone Cougar 286, 8,400lbs loaded, pulled with a 2004 F150 Supercrew, 5.4, 3.73 gears. Retired and enjoying life
dubdub07
Colorado Springs
Just bought a new Montana HC and it has the a new shortbed friendly cap and I believe I can get to 90 degrees. I never really need to and the times in 4 years I need to turn it 90 degrees? Zero. (and I have a slider and never, ever use it; but it is nice to have...just in case!)
2012 Montana High Country 333DB
*NEW* 2012 Dodge 3500MEGA 6.7 CTD, 2012 Jeep JK Rubicon, 2012 Durango Citadel, 2010 Harley Heritage Softail....American STEEL = American profits.
webslave
Clearville, PA
I have a short bed RAM (6.5') and a 318SAB Cougar on a Companion hitch. They, too, advertised 88 degrees which I could easily do... I replaced the stock pin box with a Tri Glide TrailAir unit and it is a tad longer than the stock pin box. I can now, easily attain 90+ degrees. I, personally, strive never to get in the situation where I would need 90 degrees (very bizarre what a 90 degree pivot does to the tires and axles...I saw another camper do it one time by accident; he had gotten himself into a "fix" and was trying to get out of it) and to date have been successful in avoiding that situation, but, it is comforting to know that I can attain it without the use of a slider. The Companion hitch breaks into two pieces that I can get out of the truck solo; I'd need a hoist or leave the hitch coupled to the king pin to get one of those heavy sliders out by myself.
My 2 cents, your mileage may vary...
Don
Bronwyn
3 Cats - Coco, J-Lo and Ragamuffin
2011 Keystone Cougar 318SAB
2011 Ram 2500 Longhorn CTD HO
Built in brake controller and exhaust brake
Tri Glide TrailAir Pinbox with a B&W Companion Hitch
portablevcb
Tijeras, NM
My Tundra was short box and I did not have a slider. Never needed it, just pay close attention!! I did come very close a couple of times. But, not when backing. It was when trying to get through a gas station going forward!
Dodge has a slider and have never NEEDED it. But, I routinely use it when in tight quarters just because the trailer responds faster to steering inputs with the pin back farther.
2009 Dodge 2500 Double Cab Cummins
2003 Skyline Nomad 24ft Fiver
Me and Wife
Maggie the Old English Sheepdog
GR8DANE
Utah
It works for me. I can get the 88 degrees they advertise with my Enduramax and my Ford F350 CCSB.
2011 Gulf Stream Enduramax 3310END
2011 Ford F350 CC/SB
Way too many dirt bikes
Blue Ribbon Coalition, USA-All
My Enduramax Toy Hauler Review Blog
Louba
Delaware, Ohio
I can't speak for all brands but it certainly works with my Bighorn. I have a short bed Chevy and I have made a turn farther than I think I would ever want to and still had a foot of room to spare.
Lou
2011 Bighorn 3385RL
2005 Chev 2500HD LS 4x4 D/A
Curt 20K
Mile High
Denver, CO
portablevcb wrote: My Tundra was short box and I did not have a slider. Never needed it, just pay close attention!! I did come very close a couple of times. But, not when backing. It was when trying to get through a gas station going forward!
Dodge has a slider and have never NEEDED it. But, I routinely use it when in tight quarters just because the trailer responds faster to steering inputs with the pin back farther. And what did you tow with the Tundra? That Nomad? I guarantee I wouldn't need a slider either with the extended pin on that Nomad. Probably wouldn't need one with a 5-1/2' bed on a Ranger either. The lighter the rig - the longer the pin. Look at those old Teton monsters- the pin went straight down.
2006 Ford F350 4X4 SB CC SRW Powerstroke 6.0
2013 Redwood 36RL - full paint - disk brakes
"Comparison is the thief of joy! - Theodore Roosevelt"
big bird 2
La Crescenta, CA
There are variables to consider. For example, you come out of a truck stop with a steep downhill driveway and you need to make a sharp turn to get to the street. At some point you will have the truck even on the street and the FW on the steep slope. If you are close to a 90 degree turn at this point you could take out the rear window. There are other situations, usually backing up, that can get you out of position as well.
I do not think a slider is expensive. Maybe a couple hundred bucks and could be good insurance. A rear window can cost a couple thousand plus body work.
I guess it all comes down to how lucky you feel.
Big Bird 2
garysol
Avon Ohio
Read what big bird stated above. Testing in a flat parking lot is all fine and dandy but there will come that time when the trailer either has to rise or drop on one side and then its a new set of circumstances.
2008 Dodge Ram 3500 6.7 CTD SRW, Pullrite Superglide 18k.
2012 Komfort 3530fbh 5th wheel with Ground Control
