RV.Net Open Roads Forum: Class C Motorhomes: Small, portable air compressor
 > Small, portable air compressor
dufferdj
Colorado/Arizona
Posted: 03/27/12 06:21pm Link  |  Print  |  Notify Moderator
I would like to purchase a small portable air compressor that could be used to bring the tires on our RV back up a few pounds to the 80-85 PSI range prior to heading out on a trip or while on the road. Anyone have any personal experience with a particular brand and model that they could recommend? If you know of one that could also be used to blow out the water lines during the winter that would also be a big advantage. Thanks for any and all feedback.
donn0128
Pronounced Ore-gun
Posted: 03/27/12 06:32pm Link  |  Print  |  Notify Moderator
Sears usually has their small 120 volt model for around a hundred dollars or less. For around 60 dollars you can get a nice 12 volt model that will do the same thing.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
polish al
trenton nj
Posted: 03/27/12 06:33pm Link  |  Print  |  Notify Moderator
powertank.com i have 2 10 lbs. tanks ..its compressed air , abit pricey but its worth it for me. i have a 4wd minnie winnie and i air down to 20 lbs. i can get on full fill up of 6 tires to 80 lbs. each and have enough left over for maybe another fill. it cost me 13 dollars to fill a tank with co2.
Bordercollie
Garden Grove, CA, USA
Posted: 03/27/12 06:45pm Link  |  Print  |  Notify Moderator
Adding air into a tire to get it up to 80 psi requires a compressor that can deliver over 100psi. Most small compressors require some patience building up 100psi. I have a 2-gallon 120 vac Campbell Hasusfeld that can do it, but just barely. Harbor Freight sells a knock-off that looks just like mine. Inexpensive 12 volt compressors may not be up to the job. Check the specs, try it out, and return if it can't do the job. There was a recent thread abut this,on this forum. BTW, gas stations often can't provide 80 psi.
vladen
Louisiana
Posted: 03/27/12 06:51pm Link  |  Print  |  Notify Moderator
Tired of buying those pack away 12 v and even had the sears 120 that went belly up going to get an oiled Emglo 4 gal carpenters model
Vlad's busy workings
All hope is gone
fandango49
Severna Park, Maryland
Posted: 03/27/12 07:20pm Link  |  Print  |  Notify Moderator
After reading this post, started a search and found this:
http://www.oasismfg.com/?gclid=CM6Uwfq1iK8CFWcQNAodCAOf-g
Jtroop1
Michigan
Posted: 03/27/12 07:36pm Link  |  Print  |  Notify Moderator
I bought a Slyme 230 psi model at Meijer a few years ago. It does a good job.
2010 Fleetwood Encounter 32BH
Jim Shoe
Amelia, OH
Posted: 03/27/12 07:54pm Link  |  Print  |  Notify Moderator
A few years back, I bought a Husky Air Compressor from Home Depot. It has wheels and an extendable handle to roll it around, and allows you to set the pressure you need. Stops when you reach that pressure and I've found it to be within a couple of pounds.
Retired and visiting as much of this beautiful country as I can.
IAMICHABOD
Sunny So Cal
Posted: 03/27/12 08:22pm Link  |  Print  |  Notify Moderator
My kids use the Porter c 1010 when offroading small and high output for their offroad racing try the c1010
2006 TIOGA 26Q CHEVY 6.0 VORTEC
Recycled El Monte RV Rental
Buying A Rental Class C
2oldman
Winchester WA
Posted: 03/27/12 08:25pm Link  |  Print  |  Notify Moderator
Tsunami compressor
12v compressor 2010
Compressor 2009
Compressor 2010
Compressor 2011
