RV.Net Open Roads Forum: Travel Trailers: Smoke alarm chirping
 > Smoke alarm chirping
Chuck&Gail
In the Colorado Mountains
Posted: 03/27/12 08:58pm Link  |  Print  |  Notify Moderator
You didn't try to use a rechargable battery I hope. Some (all?) of those put out a lower voltage even when new.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
barbhalsell
United States
Posted: 03/27/12 09:20pm Link  |  Print  |  Notify Moderator
I thought I read that smoke detectors had a a useful life of about 7 - 10 years.
I can attest to that in our stick and brick. And of course the ones that go bad first are the highest and hardest to get to.
dodge guy
Bartlett IL
Posted: 03/28/12 05:10am Link  |  Print  |  Notify Moderator
Are you sure it`s a smoke detector and not a carbon monoxide detector? I know CO detectors are only good for 7 years!
Wife Kim
Son Brandon 11yrs
Daughter Marissa 10yrs
Dog Shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear 5Star tuner Y-pipe mod Hellwig sway bar
Reese HP dualcam Prodigy brake controller
A bad day of camping is
borntwotravel
Central IN
Posted: 03/28/12 06:14am Link  |  Print  |  Notify Moderator
Blow the dust and cob webs off of the sensor. That may clear up your problem.
DE88ROX
West Michigan. The other West Coast
vladen wrote:
Hehe yea quality control aint what it used to be test the battery
Tell me about it!!!
My brand new-never been camped in- TT has been at the dealer for over a week making repairs on things that should've never made it out of the factory let alone the dealer!!!!
TV- 2010 GMC Sierra Z71 EXT. cab
TT- 2012 Starcraft Autumn Ridge235fb
wjpitura
Lake Country, British Columbia, Canada
Posted: 03/28/12 09:33am Link  |  Print  |  Notify Moderator
As mentioned earlier, I think it is your carbon monoxide detector that is chirping. Usually, if left in cold weather (ie storage)and the trailer gets cold, they will chirp every minute or so. With no heat, the cold temp prevents them from operating properly.
Suggest simply remove batteries...stops chirping, then reinstall them when you start to use trailer, or weather warms up.
That's how mine works, and device works fine when we use the trailer.
-- JP
sbowman871
Wilmington, Ohio
Posted: 03/29/12 06:28pm Link  |  Print  |  Notify Moderator
X2 Smoke detectors works like an indoor air cleaning machine. It inoinzes the smoke (particulate) to activate the alarm. Give it a good cleaning inside and out.
2010 Everlite 29FK
2011 Ford F150 V6 Ecoboost Max Tow 3.73
CavemanCharlie
Storden,MN
Posted: 03/30/12 04:36am Link  |  Print  |  Notify Moderator
oops, my mistake put this reply in the wrong post.
