RV.Net Open Roads Forum: General RVing Issues: OK this is gonna sound stupid
 > OK this is gonna sound stupid
halibutman214
Oregon
Posted: 03/28/12 07:42am Link  |  Print  |  Notify Moderator
hershey wrote:
I would let perhaps 10 lbs of air out of the tire and then check the pressure.
Then I'd try again to raise the pressure. Does it return again to that 95 lb number??? or will it not allow you to raise the pressure again.
Do this and if it doesn't work let some more out and try again. You will then know if it's the compressor or the valve stem. Unless you don't have that little gate valve open on the air compressor I'm guessing it's the chuck.
2008 Dodge Ram 6.7 Laramie SRW SB
2012 Keystone Passport 26BHWE
2009 Lance 830 with Tent foldout
20' North River Seahawk Boat
2005 Honda VTX1300
Traveler II
Minnesota
Posted: 03/28/12 08:10am Link  |  Print  |  Notify Moderator
The same thing happen to us, I replaced my compressor with one that goes to 150 psi.
2011 Cameo 34SB3
2014 Ford 350 King Ranch (on order), Trailer Saver BD3 Air Hitch, Mor/Ryde pin box, IS Suspension, Disk Brakes
Nights Camped in 2011 - 165
Nights Camped in 2012 - 142
Nights Camped in 2013 - 101
AO_hitech
SF Bay Area
Posted: 03/28/12 08:55am Link  |  Print  |  Notify Moderator
AndreC wrote:
You should also check the air chuck. I bought two, both had 90 lb maximum printed on them.
Bought a Heavy Duty check with no presure limit, worked fine.
+1. I've had cheap chucks refuse to work when the supply pressure was greater than about 60 psi, regardless of the tire pressure.
slickest1
canada
Posted: 03/28/12 12:18pm Link  |  Print  |  Notify Moderator
I would run it down to the nearest tire shop and get them to fill the tires. If they have no problem then you will know it is your compressor.
2000 H.R. Imperial 38wds rr8r roadmaster, isc 350 cummins
2007 Chevy Trailblazer, Blue ox towbar
Ready Brake with breakaway.
dewatkins
Dallas Texas
Posted: 03/28/12 12:53pm Link  |  Print  |  Notify Moderator
I just got back from Discount Tire and they fill all four tires with nitrogen to 75 lbs free they never charge me I know it is not 125 lbs but I am sure they will do them also.
Just Bob
SD/CT/FL/WY
Posted: 03/28/12 04:36pm Link  |  Print  |  Notify Moderator
pianotuna wrote:
Hi,
My 120 lb compressor can just *barely* do 85 lbs. To do that I sometimes have to deliberately let some air out of the compressor tank--then let it cycle. This gets "old" rather fast with six tires and two air bags (don't forget the spare, too). When this compressor dies I'll look for one that is 130 lbs.
You may need a higher pressure compressor.
Amazon.com has a 150psi pancake compressor w/dual gauges for a very good price.. I love mine, I think it's a Porter-Cable.
sc3283
St Louis
Posted: 03/28/12 10:29pm Link  |  Print  |  Notify Moderator
how long of an air hose? Pressure drop does occur in an air hose. If hose is long and or small diameter I'd bet you don't have the pressure you think at the end of the hose
04 D-Max Crew Dually
96 Monaco Dynasty 36'
Big Katuna
Deland, FL
Posted: 03/29/12 05:51am Link  |  Print  |  Notify Moderator
I think this is incorrect. The volume may decrease, but not the pressure.
My Kharma ran over my Dogma.
JoeH
Apollo Beach,FL
Posted: 03/29/12 06:46am Link  |  Print  |  Notify Moderator
I actually does decrease with length of hose. When I used to do custom painting, I had to compensate pressure at the regulator based on hose length plus I had a guage I put on at the end of the hose to check before hooking up the gun . Here's a sample chart of pressure drop
md2lgyk
WV
Posted: 03/29/12 07:40am Link  |  Print  |  Notify Moderator
Not pertinent to the thread, but an interesting and funny story:
My wife called the other day from a gas station where she was putting air in one of her car's tires. Said she couldn't put enough in and was having trouble holding the chuck on. When I asked her what the sticker on the door jamb said the pressure should be, she said "220." Since I'm the engineer in the family, I had to explain that that number is the pressure in kilopascals (metric). It's equal to 32 psig.
"The great object is, that every man be armed. Everyone who is able may have a gun." - Patrick Henry
