RV.Net Open Roads Forum: Class C Motorhomes: No Power To Outlet
 > No Power To Outlet
63StingRay
Oklahoma
Posted: 03/28/12 06:37pm Link  |  Print  |  Notify Moderator
Now that I have power to the TV, I have no signal. I hooked up a small 12" tv and it worked. I then hooked a different 23" tv and it said "low signal". Will the system not work while running the generator and only work on shore power?
crawford
Dandridge Tenn.
Posted: 03/28/12 09:35pm Link  |  Print  |  Notify Moderator
did you turn on booster switch on? for Ant.
63StingRay
Oklahoma
Posted: 03/28/12 10:12pm Link  |  Print  |  Notify Moderator
Yes, the booster is on (the little red led is on)
rvten
Crossville,TN
Posted: 03/28/12 11:49pm Link  |  Print  |  Notify Moderator
Are the TV,s digital and not the old analog TV?
You will have to adjust the antenna for strongest signal for each channel with digital signal.
Shore power and Gen will power your AC outlets the same.
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008 Type C
Ford Flex SEL 2010
There is no B+
63StingRay
Oklahoma
Posted: 03/29/12 09:42am Link  |  Print  |  Notify Moderator
the tv is digital.What kind of reading should I get on the cable going into the tv? There is about 14 volts going into the antenna on the coax cable.
rvten
Crossville,TN
Posted: 03/29/12 12:39pm Link  |  Print  |  Notify Moderator
The low signal would be the incoming signal from the TV broadcast.
Are you close to or under trees?
Adjust ant direction for strongest reception.
Not all station will be good.
63StingRay
Oklahoma
Posted: 03/29/12 05:12pm Link  |  Print  |  Notify Moderator
Took the RV over to the Hard Rock Casino parking lot. Nothingbut wide open spaces and still no tv picture. Adjusted antenna with generator on.Replaced the antenna amplifier ($45) and still don't have squat.
judelaurenzo25g
Downey, CA
Posted: 03/29/12 05:21pm Link  |  Print  |  Notify Moderator
I had the same problem just sitting in my drive way. I set the TV to auto channel search and it picked up hundreds of channels I couldn't set manually.
A ship in harbour is safe, but that is not what ships are built for.
63StingRay
Oklahoma
Posted: 03/29/12 06:17pm Link  |  Print  |  Notify Moderator
I went thru the auto scan and didn't pickup anything.
rvten
Crossville,TN
Posted: 03/29/12 07:05pm Link  |  Print  |  Notify Moderator
Is the TV hooked up through a video switch box?
