RV.Net Open Roads Forum: Tech Issues: Recommendations for an inverter?
 > Recommendations for an inverter?
jdiffend
Denver, CO
Posted: 03/27/12 11:06pm Link  |  Print  |  Notify Moderator
I'm looking for recommendations for an inverter for my 2005 Cedar Creek Day Dreamer 5th wheel.
I want to be able to watch TV (42" LED TV + Sat receiver), run a convection/microwave oven, coffee pot (and similar electric appliances), etc...
The LED TV takes half what my old LCD required so it isn't exactly a big power eater even when combined with my Blu-ray player or XBOX, but the convection/microwave will probably be the deciding factor. I couldn't find a manual for the exact model on the manufacturers website but I do have a Kill-a-Watt to check it with if needed. I figured I'd need a 1500 watt inverter just because of the microwave.
Now, I also have a residential style fridge which I think has it's own inverter (new Cedar Creeks I've looked at with residential fridges do) but I'm tracking down an electrical issue and I'm not certain yet. If it has it's own I'd like to leave it on it's own circuit so I can turn off the 2nd inverter and still run the fridge. If it doesn't have it's own, is one inverter going to be more efficient than two? What efficiency should I be looking for (other than as high as possible)? 90%? Better?
Are there any other features I should be looking for?
BTW, my electrical issue is that the fridge and TV work when plugged into 110 but they don't when plugged into a 50 amp plug. Bad converter or inverter maybe? It's a new 50 amp outlet at my house but I saw them test it after installing it today. I guess I'll have to get the multi-meter out.
If anyone has the same model Day Dreamer I'd like to know if yours came with an inverter.
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 03/28/12 12:15am Link  |  Print  |  Notify Moderator
Better make sure you have enough batteries to run that TV. They use a lot of power. One of the better inverters on the market today is a Magnum pure sine wave. The Xantrex are garbage.
jdiffend
Denver, CO
Posted: 03/28/12 03:39am Link  |  Print  |  Notify Moderator
VIZIO says the TV is 115 watt but I didn't get anything close to that on the Kill-a-watt.
My 5er came with 3 Interstate batteries (which may be a problem) but I planned on going to 4 when these die. I haven't pulled the batteries to see what voltage they are. It's a tight compartment.
The RV has a Parallax 550 converter/charger and I was also going to add solar panels later this year if that makes any difference.
The Texan
Cascade or Meridian, Idaho
Posted: 03/28/12 07:52am Link  |  Print  |  Notify Moderator
We run our entire motorhome on a 2kw Magnum ME2012 inverter, which is also a 100a 4 stage battery charger. That includes a standard house micro/convection oven, all electronics, the DWs hair dryer, etc. I am in the process of changing the ME2012 2kw inverter to a ME2512 2½kw inverter, as we are looking at going to a residential fridge. There is NO need for the expense of a PSW inverter, unless you are a electronics geek. Everything we have, including our heated mattress pad and coffee maker work fine on a MSW inverter. Check around and you will find several sources for Magnum ME2012 or ME2512 inverters at a very reasonable price.
Bob & Betsy(FishNFanatic) - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
'05 HR Endeavor 40PRQ, 400 Cummins-Pulling our '11 Silverado LT, Ex Cab 6.2L NHT 4x4, w/2010 Rzr or 01 V Star in back.
Where the wheels are stopped today
BFL13
Victoria, BC
Posted: 03/28/12 06:58am Link  |  Print  |  Notify Moderator
Check the AC input requirement on the back label of your microwave.
A 1000w MW wants 1500w input. Think 2000w inverter not a 1500w one. (assumes a PSW inverter)
2003 Chev 2500HD Gas, 2003 Komfort 26FS 5er
See Profile for Equipment List
Crazy Ray
Monroe,La
Posted: 03/28/12 07:25am Link  |  Print  |  Notify Moderator
Go to rv Tech library click on SITE and read. JMO
RET ARMY 1980, DW Donna , "Tiny" (furkid) . Class A, 2007 Bounder 35E, Ford Chassis, 4 SAMS 6VOLTS,405W Solar,TriStar 45 Controller,1750W INVERTER, YAMAHA 2400, TOW: Honda CRV. READY BRAKE. "Living Our Dream". NASCAR FAN 14,18,20,11 LOVE CO & NM
jdiffend
Denver, CO
Posted: 03/28/12 08:16am Link  |  Print  |  Notify Moderator
I'm an electronics geek (software engineer) so I'm probably stuck.
BFL13
Victoria, BC
Posted: 03/28/12 08:37am Link  |  Print  |  Notify Moderator
When I said "assumes PSW" I meant for pulling 1500w with the 150amp battery draw that goes with that. Our 2000w MSW inverter actually has the "1000w " MW pull less than 1500w because the MW won't run at full power from MSW, so the battery draw is more like 120a. The MW works but not as well as if it were on PSW or shore power/gen 120.
Because of that we could operate the 2000w inverter to use the MW (a little) on a bank of three 27DCs. It is all easier though with the four 6s we have now.
smkettner
Posted: 03/28/12 08:45am Link  |  Print  |  Notify Moderator
I have a Prosine 1800 that powers the microwave and one added outlet in the kitchen to cover all the big stuff. The rest of the outlets are powered by a GoPower 300w inverter to cover the small stuff. Both sine wave. Both work perfectly.
I added the large inverter first and was using a small MSW in the 12v connector for the tv. As other toys and gagets accumulated it became a tangle of cords so I wired in the small inverter. Could have connected the Prosine but it tends to have a high idle draw for watching a movie or charging a phone.
675 watts solar
BFL13
Victoria, BC
Posted: 03/28/12 09:01am Link  |  Print  |  Notify Moderator
Nit picking terminology, but some recent tests with various sized invetters showed that it is not the "idle draw" that adds to the appliance draw that makes it inefficient to use a big inverter on a small appliance. It turns out that the inverter has an efficiency curve for the watts of the appliance wrt the max watts of the inverter, with peak efficiency typically maybe at 75% ratio.
This is what makes it efficient to "size" the inverter to the appliance load in watts. So if your load is x then add 1/3 to get the best inverter size. eg, load is 300w so inverter should be 400w to be near peak efficiency. (very approx and peak % varies with inverters too--just rule of thumb stuff ---experts on here can refine the "rule" if worth it)
