RV.Net Open Roads Forum: Truck Campers: Has anyone had this happened to them?
 > Has anyone had this happened to them?
gpascazio
Chicago
Posted: 03/28/12 07:13am Link  |  Print  |  Notify Moderator
Yesterday I was riding in the pickup without the TC and lost my tailgate when I went over a bump. PU is a 2008 Ford F350 dually. Nobody got hurt the tailgate just fell (luckily)to the road. However it is pretty badly scratched and dented. The body repair place looked over the whole tailgate to figure out what went wrong but could not find anything wrong.
6.4 L Diesel
2010 Eagle Cap 1160
mobilefleet
on the road
Posted: 03/28/12 07:19am Link  |  Print  |  Notify Moderator
latch mechanism failure or you didn't have it latched well to begin with. If it is lockable, lock it next time before you drive away and test it to make sure it's locked
korbe
Northern California
Posted: 03/28/12 07:21am Link  |  Print  |  Notify Moderator
If latched properly, I can't see how a tailgate could fall off. What about the cables? Were they not connected either?
2004 F250 SD PSD
2004 Crossroads Cruiser CF25RS
halibutman214
Oregon
Posted: 03/28/12 07:26am Link  |  Print  |  Notify Moderator
Ditto! I'm guessing the tailgate can be removed by lifting it up a bit and pulling it out as it does on most trucks but IF the cables were connected.... I don't think so.
2008 Dodge Ram 6.7 Laramie SRW SB
2012 Keystone Passport 26BHWE
2009 Lance 830 with Tent foldout
20' North River Seahawk Boat
2005 Honda VTX1300
tomve
Bay Area, Ca.
Posted: 03/28/12 09:38am Link  |  Print  |  Notify Moderator
Very strange...If the tailgate was installed properly, that is with cables attached and properly installed on the hinges, I find it hard to believe it could come loose and fall to the ground. My suspicion would be someone messed around with it and disconnected the cables and possibly removed it from the hinges and rested it in place against the bed. Thus making it look like it was properly in place. JM.02
'06 F350 CC SRW 4x4 PS SB
'04 Lance 820
Old-Biscuit
Across the USA
Posted: 03/28/12 09:55am Link  |  Print  |  Notify Moderator
Operator error......
ticki2
NH
Posted: 03/28/12 10:29am Link  |  Print  |  Notify Moderator
I tend to agree . All the tailgates I've seen have to be at a specific angle to disengage either the left or right hinge and then pull it from the other to remove . If the cables were attached , even if it bounced at that angle it would have dragged behind the truck by the cables .
'68 Avion C-11
'02 GMC DRW D/A
JacintoKid
San Antonio, Texas (formerly sheepdog)
Posted: 03/28/12 10:35am Link  |  Print  |  Notify Moderator
These things get stolen all the time. I wonder if somebody was in the process of stealing it when something scared them off
07.5' Dodge 3500 DRW 4x4 L/B Cummins
08 Arctic Fox 990
(2) KLX 400's and a flotilla of small boats
mkirsch
Rochester, NY
Posted: 03/28/12 10:53am Link  |  Print  |  Notify Moderator
Either someone was messing with your tailgate or you're not telling us the whole story.
The only way a properly latched, properly attached, tailgate could come off is if you hit a BIG bump REAL hard.
2002 Chevy 3500 DRW 8.1L/Allison
2000 Palomino B1500
...and the reason why I need a DRW to haul a Palomino:
2004 United 7x14 tandem axle enclosed toy trailer
2011 PJ 8x20 7-ton deckover equipment trailer
recycler
michigan
Posted: 03/28/12 11:08am Link  |  Print  |  Notify Moderator
i think someone was in middle of stealing it they tend to stay latched decent, but as to the cables holding it on i have yet to work on a pick up with tailgate cables that aren't broke and one of them is only a couple of years old
1968 franklin 11fk
back to my 93 cummins
