RV.Net Open Roads Forum: Class A Motorhomes: Fleetwood Drawers and Woodwork
 > Fleetwood Drawers and Woodwork
balfre1946
travelling
Posted: 03/28/12 09:36am Link  |  Print  |  Notify Moderator
We have a 2010 Fleetwood Fiesta 34B and the edges of the drawers are all chipping and peeling. Fleetwood was of absolutely no help, said it was humidity (we are in Palm Springs..desert) and some of what we thought were wood finishes seem to be contact paper. Any recommendations on how to repair them? We are VERY disappointed in Fleetwood., and this is a relatively new rig.
deandec
Northern CA
Posted: 03/28/12 09:47am Link  |  Print  |  Notify Moderator
You could have new drawer fronts made for replacement using the original as the model. Chips would be hard to repair to look good.
Dean
95 CC Magna, Jeep GC
hershey
Albuquerque,(fulltime) NM, USA
Posted: 03/28/12 09:52am Link  |  Print  |  Notify Moderator
The above is a good recommendation.
A possible alternative would be new contact paper? Use wood filler to fill in the chips and then use a matching contact paper of the entire drawer?
Not sure that new fronts can be matched to the existing cabinetry but of course that would be the best alternative.
hershey - albuquerque, nm
Someday Finally Got Here
Superman was an illegal alien.
NASCAR 14 - 99
balfre1946
travelling
Posted: 03/28/12 10:11am Link  |  Print  |  Notify Moderator
The rig is barely a year old..do other people have this problem with Fleetwood? We are simply amazed in a $130,000 rig to have such CHEAP workmanship
wildmanbaker
Kennewick, Washington
Posted: 03/28/12 10:55am Link  |  Print  |  Notify Moderator
I believe that the drawer fronts and cabinet doors are all solid wood. In 2010, this was a middle gas MH, and should have pretty good quality. You can get new Drawer fronts, or doors from Fleetwood, at a pretty reasonable price.
Sorry about your problems
Good luck
Wildman
weathershak
Not sure, I need to look out the window
Posted: 03/28/12 11:08am Link  |  Print  |  Notify Moderator
Ours is 10 years old, no problems.
Full timing it since July 2012 My pics
janstey58
Glenwood, IA
Posted: 03/28/12 11:26am Link  |  Print  |  Notify Moderator
Ours is 3 years old, very happy with the workmanship of Fleetwood.
Jeff and Kim
2009 Bounder 35H (Gas Workhorse chassis)
2012 Ford Escape Limited Toad
n7bsn
Yes
Posted: 03/28/12 12:43pm Link  |  Print  |  Notify Moderator
Actually contact paper is very common. Some of it is good, some not so.
The real easy way to tell on the best, is to look at the rails and stiles of a door (the frame) if you don't see ANY End-Grain wood, it's a contact cover.
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
jones4110
Champlin, MN
Posted: 03/28/12 01:03pm Link  |  Print  |  Notify Moderator
The fiesta is an entry motorhome. My Excursion DP has maple door fronts ad the added cost. Cabinet materials should be on your review list when purchasing if it important to you. Fleetwood generally offers a big bang for the buck. The more bang you want the more bucks are required. JMO
Joan and Bruce
05 Excursion 39L
powered by 350 KittyCATS on a Spartan
2010 Traverse LT toad (Blue Ox & Breakbuddy)
...and a "road dog" named Max and his gabby sister, Abby.
"May the wind be always at your back and your destination the one you chose"
wilanddij
CA Desert
Posted: 03/28/12 09:59pm Link  |  Print  |  Notify Moderator
If your drawer fronts and cabinet door frames are not real wood, no amount of fixing is going to make them look good for long. Best to change them out for real wood.
My Southwind has covered particle board for the cabinet sides and fronts, but the drawers and door frames are genuine maple. That was one of the things I remember looking for back in 2004 when we bought the coach. It was easy to see what was and what wasn't.
Will & Di
2004 Southwind 32VS
Workhorse/8.1
Jeep Wrangler/Blue Ox
"We have met the enemy, and he is us" Pogo
