RV.Net Open Roads Forum: Class C Motorhomes: Leveling jacks on class C
 > Leveling jacks on class C
judelaurenzo25g
Downey, CA
Posted: 03/28/12 05:39pm Link  |  Print  |  Notify Moderator
Im curious as to how many "C" owners actually have leveling jacks. How much would they cost to install?
Thanks
A ship in harbour is safe, but that is not what ships are built for.
beachball42
Indiana
Posted: 03/28/12 05:51pm Link  |  Print  |  Notify Moderator
I do not have leveling jacks. I haven't seen any with them when I walk around so I don't know how common they are. What I did was build some ramps that I carry with me and have never had a problem.
Don't know how true this is but when I bought our MH three years ago I asked about leveling jacks and they dealer told me not to put them on as they can twist the frame and cause problems. He said that "C's" weren't really designed to have them. I know you can get them but I've just never have had a problem that my homemade ramps can't solve.
ASPENMAN
New Mexico
Posted: 03/28/12 05:53pm Link  |  Print  |  Notify Moderator
I've had Big Foot levelors installed on my 31' NEXUS RV. The levelors and installation was under $3000. IMHO well worth it.
BLOGS:
http://rvpainter.blogspot.com
http://art4rvs.blogspot.com
31' Class C NEXUS Phantom 4/4/12
Pressure Pro TPMS
Progressive Industries EMS/Surge
WiFi Ranger Mobile
Cab over entertainment center
judelaurenzo25g
Downey, CA
Posted: 03/28/12 05:58pm Link  |  Print  |  Notify Moderator
Can I get a picture of the ramps you built?
bukhrn
Lanexa, Va
I've seen a few C's with stabilizer jacks, but Not with leveling jacks, although I do know that you can get them.
2007 Forester 2941DS
2005 KIA Spectra
judelaurenzo25g
Downey, CA
Posted: 03/28/12 06:07pm Link  |  Print  |  Notify Moderator
Are these the one levelers your have? clicky
fredandkathy
Johnstown, PA
Posted: 03/28/12 06:10pm Link  |  Print  |  Notify Moderator
I have Big Foot Levelers on my Granite Ridge. I will never have another MH without them.
Eyegor
NY
Posted: 03/28/12 06:41pm Link  |  Print  |  Notify Moderator
no levelers or stabilizers for me.The normal play of the suspension doesn't bother me and I currently carry around a small lumberyard for leveling. Hoping to pick up some legos this spring.
87 Mallard Sprinter 24' Class C Ford E350 w/460 gas "The Runny Duck"
Shiny side up, Rubber side down.
beachball42
Indiana
Posted: 03/28/12 06:43pm Link  |  Print  |  Notify Moderator
Sure, I just brought my MH to the house tonight. I'll take a picture of the ramps in the morning and send. I found the instructions to build them in a post on here three years ago.
Found these similar instructions via a Google search. I did not use dry wall screws and I did not paint the wood. I made a total of four ramps. They can get a bit heavy.
Materials List
1 - 10 foot, untreated (I'll explain later) 2" x 10"
12 - 1-1/2" Dry Wall Screws
Good Quality Waterproof Paint
Construction
Cut the first piece to 3 1/2 feet long, with a 45 degree bevel at one end. Cut the second piece to 2 1/2 feet long, again with a 45 degree bevel at one end and cut the third piece to 1 1/2 feet long and bevel one end to 45 degrees.
Stack the 2 1/2 foot piece on top of the 3 1/2 foot base, line up the sides and the butt ends and attach using 8 drywall screws spaced two across and evenly distributed (make sure the screws are countersunk into the piece to avoid tire damage). Stack the 1 1/2 foot top ramp at the top of the stack, line up the sides and the butt ends and attach with 4 drywall screws, again, countersunk. Sand thoroughly to remove any splintered surfaces and protect with a good quality waterproof paint.
Properly constructed and with reasonable care, this ramp will last a lifetime.
Note: I do not recommend using treated lumber to build your ramp. Treated lumber is soaked in arsenic or other hazardous preservatives to slow decay and/or discourage infestation by termites and
* This post was last edited 03/28/12 07:06pm by beachball42 *   View edit history
Tothill
BC
Posted: 03/28/12 07:01pm Link  |  Print  |  Notify Moderator
Mobi is 27 feel long and we level using Lego and a couple pieces of wood. Never had any issues with getting level.
We have a couple stabilizing jacks but rarely use them.
We do not have any slides.
