MM49
Brighton, MI, USA
I doubt that many on this site have ever balanced a load on a construction trailer. They need to spend a little time on the farm to learn how to work.
MM49
LarryJM
NoVa
donn0128 wrote: The Mad Norsky wrote: Experience may be the key here.
You obviously have much experience towing heavy (or even heavier  ) loads than a lot of people who post here.
Now it is one thing to know what you, yourself, can handle with your vehicle. It is entirely a different situation to promote such practices with a stranger of unknown experience or ability.
It is therefore common sense to publicly, such as on a forum as this, to promote or urge towing practices which for most people, would stay within manufacturers limits for their respective vehicles. To do otherwise could actually be putting a novice driver into an unsafe situation.
It is not unreasonable to observe that there are a LOT of posters on here, asking questions, who have never actually towed a fifth wheel or trailer of any type before. Good grief, look at the one thread where the poor poster is having problems just hitching up to his fifth wheel. If this poster is such a novice in experience that he cannot easily even hook up to his hitch, how does one think he would do pulling such a load down the highway if he is extremely overloaded??????
My experience is not yours, yours is not mine. Temper observations and advice with the sense that those you are speaking to actually know and have done very little.
It doesn't matter what you have done out on the ranch.
AMEN! I could have not said it better.
X2
To the OP: posting a pic like you did maybe isn't Arrogant, but sure tells me you don't understand or appreciate what is done farming where the speeds are not that high nor the distances that great and trying to equate it to towing at highway speeds for 100's of miles at time sometimes in traffic and a very wide variety of weather conditions.
Larry
Larry
ALL TRAILER MODS>>ETERNABOND INSTALL>>RAINKAP INSTALL
Supreme Oppressor
Grande Prairie, Alberta
I don't think he was claiming that that type of load was safe to tow across the country on the interstate. He claimed his truck had a lot of power and pulled it easily.
2006 F350 6.0 diesel cc lb srw
2004 Jayco Jayflight 30.5BHS
MM49
Brighton, MI, USA
Supreme Oppressor wrote: I don't think he was claiming that that type of load was safe to tow across the country on the interstate. He claimed his truck had a lot of power and pulled it easily. Why would the load be unsafe. I bet he was under on all axles.
MM49
4x4ord
Canada
Old-Biscuit wrote: 4x4ord wrote: Old-Biscuit wrote: I don't care what the towing capability is.......seen one move a locomotive with a chain hooked to bumper.
My concern is the fool towing overloaded on the road (field towing don't matter) and the tires blow out.......you can't tell me your tires were NOT overloaded.
Trucks can handle all kinds of towing........tires get overloaded fast and are the weak link in any tow set-up.
I didn't cross a scale so can't say for cettain but my guess is a 4000lb pin weight which would not overload the tires. Although I beleive tires are, for good reason, rated with a large safety margin I would not advocate that anyone load a truck or trailer beyond its tire's rating.
4000# pin weight + 3800# rear axle=7800# rear axle load.
Tires.......probably 3400# (more likely 3200#)=6800# so yes the tires are way overloaded by 500#/each.
Tires are 3750 lbs. Axle is rated for 9750, rear uspension is 7000lbs
2011 F350 SRW short box 4x4 CC 6.7 PS King Ranch
B&W TurnoverBall and Companion
2003 Citation Supreme 34 RLTS
4x4ord
Canada
MadMav wrote: 4x4ord wrote: On I another thread i was accused of being arrogant for claiming I need a bigger trailer to find my truck's towing limit. I know allot of people on here think the gvwr numbers are some kind of magical numbers that actually mean something - I used my cell phone to make a little video that I hope gives some indication of how comfortably my F350 SRW handles a 30,000 lb trailer. This new truck is easily towing twice what it is rated for. (towing this trailer is as relaxing as taking the car for a Sunday drive) My 03 diesel didn't handle half this weight as confidently yet both are rated for roughly 15000 lb 5th wheels. My point is that the new series of diesels are much more capable than the old even though the weight ratings haven't really changed all that much. http://i1117.photobucket.com/albums/k585/4x4ord/2012-03-28155731.jpg
That's just a hair over 20k. Where are you getting 30k at? 1800 per bale and 7k for trailer. My problem is your willfull acceptance of exceeding axle limits without care. Oh, and your continuous pimping of silly Fords.
Mav
14 bales on the trailer. My guess is that the new GM and Dodge would handle the load quite well also. I've pulled similiar loads with my 03 GM and there is no comparison. I realize that the Ford has a poor exhaust brake; the Dodge a poor trailer brake control and fuel economy; and the GM a poor cab- non of them are perfect.
45Ricochet
North Idaho
Quote: My guess is that the new GM and Dodge would handle the load quite well also.
Why to you keep bringing up this "new truck" BS. We have 15 year old trucks around here doing the same thing. Unless your bragging again about being the first one up the hill. Oh that's right Chevy wins that race. You won on the downhill side though.
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
fla-gypsy
North Florida
I think the posters in the first thread were right.
MadMav
Colorado Springs, CO
Sorry, Ford does not rate the axle that high. Ford's number is the one that needs followed; the one the Canadian law states you need to follow.
I see the extra bales now.
Mav
"A fifth wheel trailer is a bi-level towable mobile home."
RVUSA
Orlando, FL, USA
MM49 wrote: Supreme Oppressor wrote: I don't think he was claiming that that type of load was safe to tow across the country on the interstate. He claimed his truck had a lot of power and pulled it easily. Why would the load be unsafe. I bet he was under on all axles.
MM49
Care to wager how far it would take or how many cars would get mowed under when he tried to keep from rear ending the wreck in front of him.
It might have the grunt to get going but it most definitely doesnt have the brakes to stop fast.
And yeh it does look like the folks in the first thread were right.
