RV.Net Open Roads Forum: Fifth-Wheels: 50 amp and 30 amp service
 > 50 amp and 30 amp service
ccjordan
Maine
Posted: 03/29/12 09:52am Link  |  Print  |  Notify Moderator
We have a new fifth wheel and the campground we at going to only has 30 amp service available. I realized that means we should not utilize Air, and other things at the same time. Can the 30 amp hurt our camper??? Thanks we are new at RVing.
JoeGood988
S.Dakota
Posted: 03/29/12 10:03am Link  |  Print  |  Notify Moderator
You can run your air, you just might trip the breaker if you turn on the micrwave, toaster & hair dryer at the same time. I always carry a reducer allowing me to step down from 50 to 30 amp. Many state & national parks are only 30 amp along with some older campgrounds. Not a problem at all.
2003 3330 Jayco Legacy
Pipeman
Windsor, Ontario,
One word answer- no. It won't hurt your trailer and you can use your AC...if you don't use the microwave at the same time. My 5er is a 50 amp hook up but I use a 4000 watt genny with a 30 amp outlet and we dry camp most of the time. If you haven't got one, get a 50 to 30 amp adapter or you can get a 50 to 30 amp power cord that hooks up to your trailer just like the 50 amp cord. Have fun and enjoy.
Pipeman
Ontario, Canada
35 year Fire Fighter(retired)
VE3PJF
Here'n'There
WA
Posted: 03/29/12 10:13am Link  |  Print  |  Notify Moderator
I don't mean to put too fine a point on this but the OP is a Newbie so let me state it this way...
You WILL NEED a 30 to 50amp adapter to plug into the 30amp power pedestal at your campsite. The reason is that the male "plug" at the end of your 50amp power cord (with 4 prongs) will NOT fit into the 30amp socket in the pedestal (3 slots).
I would go with the adapter, available most all RV supply stores as you will need it from time to time and it's much smaller that getting a whole new power cord specifically for 30amp connections.
Here'n'There
2009 Carri-Lite 36SBQ 5th Wheel
2008 Dodge Ram 3500 Quad Cab Long Bed Diesel Dually
On the road with Here'n'There
Role of the C133 in Viet Nam
bpounds
Senile, er I mean
Posted: 03/29/12 10:16am Link  |  Print  |  Notify Moderator
You can run one A/C. If you have two A/C units, one won't run.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
John Bridge
Houston
Posted: 03/29/12 10:29am Link  |  Print  |  Notify Moderator
On 30 amp I run the smaller of two ACs. I also do not allow, microwave, toaster, coffee maker, hair dryer, curling iron [emoticon], anything with a heating element to run when the AC is being used.
I have 30 and 20 amp adapters. Many parks in Canada and a few in the U.S. only offer 20. That means no AC at all unless you've got a small one. [emoticon]
Semi-"retarred" in 2006. :-) 2008 Newmar Cypress 5th wheel, 2008 Dodge diesel dually to pull it with.
Old-Biscuit
Verde Valley
Posted: 03/29/12 10:34am Link  |  Print  |  Notify Moderator
50A.....30A.......20A etc. are all 110V AC so NO you will not hurt your RV using the 30A.
As stated: You will need a 30A to 50A adapter like one of these
Plug the three prong male end into CG Pedestal 30A receptacle and then plug your 50A power cord into it.
You will only be able to pull a total of 30A......most everything will run in your RV.
Another handy device is a Voltage Monitor like this
Low AC Voltage can be very harmful.
Course you might also want to invest in a surge protector
They check that the CG Pedestals are properly wired and will trip on High/Low Voltage, auto-reset when correct voltage is restored etc. They come in portable and hard wired models.
Everything I've listed can be found at most RV outlets or on-line. The pictures are from CW site.
Enjoy your trip......
christopherglenn
Near Yosemite
Posted: 03/29/12 10:36am Link  |  Print  |  Notify Moderator
I have a 50-30 adapter that screws ont the connector on the side of my trailer, I plug that into a 30-15 and a cheap extension cord when at home. 20 amps is more then enough for any rv ac - if nothing else is on. The converter (if charging batteries) may be enough to put the combined load beyond 20 amps. Don't forget tv + satellite / dvd may be close to an amp. 30 amp service is enough for the ac and (unless your batteries are deeply discharged) the converter without problems. Think about all the 30 amp trailers that run the converter, electric water heater, and AC at the same time.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, Titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
Ashbourne
UK
Posted: 03/29/12 10:55am Link  |  Print  |  Notify Moderator
Just an aside to the OPs question
European AC voltage is 240v so is a 16amp supply the same as an American supply of 35 amps
eg. 240v at 16 amps = 3840 watts
110v at 35 amps = 3850 watts
Just curious
Mark. [emoticon]
Old-Biscuit
Verde Valley
Posted: 03/29/12 12:32pm Link  |  Print  |  Notify Moderator
Just curious
Mark. [emoticon]
Available power...yes
Except.....if you plug an RV into a 220V nothing will work cause it will be fried. 50A is two 110v hot leads, a ground and a neutral
