Brassica
Snow belt
This is a great idea.
I heard that some pickup trucks have an extra battery platform under the hood. The owner could buy an extra battery and use it to power the trailer. However, I don't know what the circuits are. All I know is that the connector supplies +12V and return to the trailer through the towing connector. Does anybody understand how to use that extra battery? Would the owner have to be opening switches on the extra battery to prevent a drain on the "real" truck battery?
MudChucker wrote: ...if it were me, I'd fab in an isolator on the trucks trailer harness... Would that be a device to protect the regular battery or to protect the truck's entire electrical system?
knesdad
Wisconsin
I have a GMC 2500HD 6.0L. It has 2 batteries under the hood. Can you explain further the isolator idea?
Thanks.
Dave.
Dave & Sue
Kiley & Emily
Izzie (Beagle/Bichon/Mini Poodle)
2012 Ford F150 XLT EB SS CRW 6.5 Max Tow
2012 Dutchmen Kodiak 284BHSL -- Dutchmen Owners
knesdad
Wisconsin
mkirsch wrote: knesdad wrote: donn0128 wrote: Don't forget though you need two wires to complete the circuit.
Please expand upon... Thanks.
He didn't read your OP. You listed two wire connections.
That's what I thought... Thanks for confirming.
BFL13
Victoria, BC
If you have the connection for a slide-in camper behind the cab as well as the bumper 7-pin , you have a choice for where to get the power. The camper connection would allow shorter wires to the battery you might keep in a locked tool box, eg.
In either case, you can get the appropriate piece that goes on or into the truck's connection and put your two wires on the pins of that, and then put clamps (red and black set) on the other ends of those wires and now you have an "adapter" you can use anytime that will stay in place.
You won't get that many amps, but you could use #8 wires and 50amp rated clamps so they are a decent size for putting on the battery posts.
2003 Chev 2500HD Gas, 2003 Komfort 26FS 5er
See Profile for Equipment List
smkettner
No isolator needed. Nothing to gain, could have voltage loss that slows charging.
No need to complicate things.
675 watts solar
mkirsch
Rochester, NY
2002 Chevy 3500 DRW 8.1L/Allison
2000 Palomino B1500
...and the reason why I need a DRW to haul a Palomino:
2004 United 7x14 tandem axle enclosed toy trailer
2011 PJ 8x20 7-ton deckover equipment trailer
dodge guy
Bartlett IL
Remeber also not to run to many amps through the 7-way. It is small gauge wire (I think 12 ga.) maybe 10, but I don`t think so. either way keep the charge amps at around 20. the charge wire in the 7-way is really only intended to maintain the charge in the trailer battery.
Wife Kim
Son Brandon 11yrs
Daughter Marissa 10yrs
Dog Shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear 5Star tuner Y-pipe mod Hellwig sway bar
Reese HP dualcam Prodigy brake controller
A bad day of camping is
