Bigdog
silverdale wa.
Hooked up the toad today while getting it ready to take off for Ca tomorrow and discovered the left turn signal on the toad wasn't working,but the one on the MH was. Dis-connected it and the turn signal worked.Put a tester on the MH plug and it's good.Plugged the cable back in and tested the toad end and it still worked.Then I plugged it into the toad and nope,it didn't work.I didn't get a chance to check it at the tail-light end of the toad,but will when I get into the RV park tomorrow night
GO COUGARS
2001 Tradewinds 7390 LTC
330 Cat Turbo Freightliner Chassis
2011 Jeep Liberty(toad)
'88 Mustang 5 Spd 5.0L GT convertible (not Toad)
rr2254545
Minnesota
Happens all the time to me it is the connection only sometimes fiddeling with the connection can i get mine to work.
hope you get an answer how to fix it I will use the answer too
2012 Winnebago Journey 36M Cummins 360
131 Campgrounds since we retired in July 2009
Corkey05
Washington State
Most coaches have separate fuses for the connector at the hitch. Usually found in an outside run bay. Worth a look.
2008 HR Endeavor PDQ - Blazer 4 Down
FMCA F374292
pulsar
Lewisville, NC
Is it a 6-pin connector. If so, the connector post for the left-turn signal in the toad socket could have been squeeze so that it won't make a connection.
You can spread the post with a small screwdriver. The post for the left turn signal is on the lower left as you face the socket, the one indicated in the picture.
Tom
kalynzoo
Los Angeles , California
Pulsar may have it right on target. This happens to me constantly. I use an X-acto knife to open up the pin(s).
Bigdog
silverdale wa.
Thanks,I'll check it in the am if it's not raining. 3" in two days and everything is a bit wet around my pad.
gotsmart
Aberdeen, WA
If you're using diodes at the toad's tail lights to isolate the pigtail from the toads's electrical system then check the diodes. You may need to crimp the spade connector on the pigtail wire so that it fits snugly onto the diode.
2005 Cruise America 28R (Four Winds 28R) on a 2004 Ford E450 SD 6.8L V10 4R100
2009 smart fortwo Passion with Roadmaster "Falcon 2" towbar & tail light kit - pictures
Bigdog
silverdale wa.
OOpss,that sounds like another out and under.I'll do the first check this morning and try to run down the diodes later.
chevylover1965
Southern CA
I just went through the same problem. I kept blowing fuses in the motor home every time I hooked up my toad to the motor home. After hours of research I finally discovered that the 6-way plug on the toad had an internal dead short. After replacing the toad plug I'm in business. Good luck.
06 Tiffin Phaeton 40 QDH
Freightliner, CAT
08 Honda CRV EXL/NAV
Roadmaster Falcon All Terrain tow bar/US Gear
FBINA 144
lanerd
Newport, OR
We had that problem last year. Spread the little prong connectors, cleaned the connectors, put dielectric grease on the connectors.... finally when everything else failed, I bought a new umbilical cable; problem solved.
Ron
Ron & Sandie
'08 Safari Simba SBD35 CAT C7
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Safari Intl, CAT
RETIRED!! How sweet it is....
