RV.Net Open Roads Forum: Hybrid Travel Trailers: AC unit gasket.
Open Roads Forum  >  Hybrid Travel Trailers
 > AC unit gasket.
Jayco25E
PA
Posted: 03/30/12 07:01am Link  |  Print  |  Notify Moderator
I have seen a few folks posting about their lose bolts on their AC units and asking questions about replacing the gasket. I replaced my AC unit gasket on my Jayco HTT and thought I would post a few photos for those who want to replace theirs.
AC Unit
2008 Chevy Avalanche
2005 Jayco 25E HTT
2 retired Greyhounds
Jayco25E
PA
Posted: 03/30/12 07:04am Link  |  Print  |  Notify Moderator
Old and New Gasket. You can see the differance. It needed to be replaced.
Jayco25E
PA
Posted: 03/30/12 07:14am Link  |  Print  |  Notify Moderator
Hole in roof.
ScottG
Bothell Wa.
Posted: 03/30/12 08:57am Link  |  Print  |  Notify Moderator
Nice write-up.
Was your gasket leaking or did you just do this as maint?
Scott, Grace and Wesly
H0NDA eu2000i
Jayco25E
PA
Posted: 03/30/12 09:29am Link  |  Print  |  Notify Moderator
ScottG wrote:
Nice write-up.
I had a leak last season and I snugged up the bolts and it fixed the leak but I noticed that the gasket was looking kinda thin so I replaced it this spring as part of my maint.
RoyB
King George, VA
Posted: 03/30/12 12:34pm Link  |  Print  |  Notify Moderator
good post - thanks for the photos...
Impressive how thin they get after being used for awhile...
I noticed you may have had your air conditoner up on its edge for awhile... Did that bother anything...
It sure is amazing that those four long bolts is the only thing holding the air conditioner down...
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
Jayco25E
PA
Posted: 03/30/12 04:01pm Link  |  Print  |  Notify Moderator
No I just gently flipped it on end and it only took maybe 30 minutes and I had it back down with the new gasket on. Did not hurt anything however you do not want to drag the unit across the roof at all. Aways pick it up and gently set it to the side. But yes it is amazing that only four bolts hold it down.
Latner
Indiana
Posted: 03/31/12 07:20am Link  |  Print  |  Notify Moderator
When I replaced mine, I bought 2 gaskets and stuck them together. My theory is that with double the gasket material, at some point the crushing of the gasket from the unit would stop and you should end up with enough gasket left that you shouldn't have to replace it again. I check the bolts once a year and snug them up if needed. So far so good.
my toys
Western MD
Posted: 03/31/12 08:58am Link  |  Print  |  Notify Moderator
Thanks for the post with pics. Very informative.
2010 Jayco 17Z
2008 Nissan Pathfinder
Nancy-USAF Veteran; Dear Hubby Joe-USAF Retired
Why do we have to push 1 for English?
 > AC unit gasket.
