RV.Net Open Roads Forum: Class C Motorhomes: Holding Tanks
 > Holding Tanks
high desert rver
New Mexico
Posted: 03/30/12 07:04am Link  |  Print  |  Notify Moderator
Should you use any kind of treatment for smell and treatment in tanks. Their are so many on the market. What works best
pianotuna
Regina, SK, Canada
Posted: 03/30/12 07:20am Link  |  Print  |  Notify Moderator
Hi,
Dump often, rinse often. Use lots of water. I don't use chemicals in mine.
* This post was edited 03/30/12 09:38am by pianotuna *
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
Riplin
Southern Ontario
Posted: 03/30/12 08:06am Link  |  Print  |  Notify Moderator
beachball42 wrote:
I do use the treatment. Don't recall the brand, just got it at Walmart. I've never had a problem with odor. I start off by putting a few ounces of the treatment and some water into the tank. At the end of the trip, I dump, rinse and then add then put in the treatment and some water and were ready for use again.
X2
skipnchar
Topeka or somewhere else
Posted: 03/30/12 09:26am Link  |  Print  |  Notify Moderator
I"ve probably used everything that's on the market and really don't notice ANY difference from one to the other. I buy whatever is lowest price. If your waste water system is working correctly using plenty of water alone will prevent odor problems but adding chemical helps breakdown solids faster.
Probably the MOST important thing that will prevent odors in your tanks is to NOT dump too often. If you dump when black tank is LESS than about 2/3 full you risk leaving solids behind which will cause odors and eventually clogs. For the SAME reason, never leave the tank completely empty. There will ALWAYS be some remaining solids left after dumping and flushing your tank and if left dry these will turn to stone and be nearly impossible to EVER remove. Result can be odors and eventually clogs.
Good luck / Skip
korbe
Northern California
Posted: 03/30/12 07:32am Link  |  Print  |  Notify Moderator
First off, are you currently having issues with odors? Or are wanting to be prepared?
2004 F250 SD PSD
2004 Crossroads Cruiser CF25RS
beachball42
Indiana
Posted: 03/30/12 07:38am Link  |  Print  |  Notify Moderator
Edward Jones-Dome
Collinsville, IL
Posted: 03/30/12 10:31am Link  |  Print  |  Notify Moderator
I recommend one of these- http://www.campingworld.com/shopping/item/cyclone-sewer-vent/31992. You can get one at Walmart and takes about 20 minutes to install. It really cut down on the amount of chemical we use.
Gerald G Todd
2 Tents, 3 Pop-ups and 3 Motorhomes (currently 2006 Winnebago Outlook 25F).
gbopp
The Keystone State
Posted: 03/30/12 10:42am Link  |  Print  |  Notify Moderator
You may want to consider The Geo Method.
gbopp
The Keystone State
Posted: 03/30/12 10:43am Link  |  Print  |  Notify Moderator
Clicky
luvztheoutdoorz1
Lincoln, NE
Posted: 03/30/12 11:37am Link  |  Print  |  Notify Moderator
Geo Method here. Has worked for me for years.
Linda
Scout, 6 year old Husky/Shepherd
2011 Jayco Greyhawk 26DS
 > Holding Tanks
