flip418
I have a 328QBS and have that same sticker. Been wondering about this very topic. Thanks for the info. Curious what size screws to use however?
The Thomas's
2012 Keystone Cougar 328QBS
2004 Ford F-250 PSD
Firestone Air-Rites
Biggziff
Upstate, NY
Perfect!
Looks like the mount you used has the same mounting point with a different (and maybe better for this application) articulating arm.
What did you use for screws? Self tapping? Sheet metal?
thanks!
Me and my 3 girls
2013 Cougar 293SAB
2011 F350 CC SWB 6.7
greende
Syracuse,NY
The kit came with 2.5 or 3 inch coarse screws. I used stainless 1.5 inch #10 screws (sheet metal). When I used the pilot drill, it went through the wallboard easy then hit what appeared to be metal as there was more resistance than wood would be. Once I was through that, ithe bit seemed to be in soft stuff again. Good luck & let me know if I can add more.
2011 Chevy 3500 HD LTZ Duramax/Allison Crew Cab Long Box DRW
B&W Turnover Ball with Companion
2012 Keystone Cougar 293 SAB 5er
rattleNsmoke
Western Conn.
You probably hit an aluminum stud in the wall. The mounting location is directly below the junction box for power\cable in the ceiling, which would be screwed to a roof stud.
Mike
2010 Cedar Creek 34SATS (The Beast) & 20k Curt Q20 roller slider hitch
2006 Ford F350 SRW,SC Powerstroke diesel Lariat
2003 Harley Heritage Softail (Hogzilla)
and a wifey with tons of patience....
Biggziff
Upstate, NY
rattleNsmoke wrote: You probably hit an aluminum stud in the wall. The mounting location is directly below the junction box for power\cable in the ceiling, which would be screwed to a roof stud.
Mike
Are you sure?
If so, why do they put the sticker on the wall indicating the place to mount the TV bracket?
greende
Syracuse,NY
Mike
I put the mount right over the sticker. The area below the junction box is where the pocket door slides all the way to the sidewall. There is no way to put the TV mount there. See link to my pic.
rattleNsmoke
Western Conn.
No, I was referring to the sidewall not the pocket door frame. That wouldn't hold squat. If there is a metal plate behind the wall it's most likely then attached to a wall stud. I'm thinking the sticker is just in a convenient location, not too high and not too low for the screen up and down the stud.
Mike
Biggziff
Upstate, NY
rattleNsmoke wrote: No, I was referring to the sidewall not the pocket door frame. That wouldn't hold squat. If there is a metal plate behind the wall it's most likely then attached to a wall stud. I'm thinking the sticker is just in a convenient location, not too high and not too low for the screen up and down the stud.
Mike
I don't think it's a pocket door. I think it slides outside of the wall.
Your original post made it sound like you knew exactly what the deal was with this unit and the mount point.
Thanks
rattleNsmoke
Western Conn.
Sorry for the confusion. I'm still thinking you hit a wall stud. If you have a 'stud finder' you'll be able to find what you need. Good luck.
Mike
greende
Syracuse,NY
Forgive me if I'm wrong, but I assumed that if there was a sticker that said a particular location was for a TV mount, then there would be some sort of blocking or support behind that area to support the mount.
