narcodog
Georgia
I have a friend that just bought an Lance 845 and is going to put it on a 2004 2500Hd swb. He has air bags on it now and wanted to put a sway bar but because of the AB's it won't mount.
So my question is AB's or sway bar? Just looking for some suggestions for him.
Personally I have SuperSprings and a sway bay and really don't care for AB's.
dadwolf2
Henderson,NV
I also found that Supersprings have some sway bar acting benefits as well.
2005 Dodge Ram 2500 CTD,4X4,NV5600,Pullrite superglide
2005 Skyline Rampage 289
2011 Outfitter Apex 8 (Love it)
Ramblin' Ralph
Central California Coast
I have the same rig. I started out with air bags only. Then a couple of years later I added Bilstein heavy duty shocks. The shocks made a major difference in the up/down bouncing. I like them.
I've never driven another truck camper, so don't know if a sway bar would help me or not. My ride right now seems pretty good. YMMV.
Ralph
2006 GMC 2500HD, XCab, SB, 6.0L w/2001 Lance 845
Firestone Air Bags, 125 watt solar
My RV Travels Webpage and Campsite Map
jmtandem
western nevada
Quote: I have a friend that just bought an Lance 845 and is going to put it on a 2004 2500Hd swb. He has air bags on it now and wanted to put a sway bar but because of the AB's it won't mount.
Maybe I am misunderstanding something here. Sway bars and air bags do not function the same and do not provide for the same solution. There will always be a little gentle sway with a truck camper of any size and weight. Air bags do not elimnate that and neither will a sway bar. What worked for me very well was to add the energy systems overload spring stops that allow the overloads to engage earlier and then add just enough air for the springs to touch with the camper on.
'05 Dodge Cummins 4x4 dually 3500 white quadcab auto long bed.
'09 299bhs Tango.
narcodog
Georgia
jmtandem wrote: Quote: I have a friend that just bought an Lance 845 and is going to put it on a 2004 2500Hd swb. He has air bags on it now and wanted to put a sway bar but because of the AB's it won't mount.
I know that there is a difference in the dynamics between AB's and a SB. My question is,which would be more beneficial AB's or SB. He is planning on upgrading his shocks.
IMO he would be better off taking the AB's off and installing a SB and some other suspension upgrade. From my understanding is that all AB's do is level the load.
wnjj
Cornelius, Oregon
Since he can only have one, I think he's asking which one will help the most.
halibutman214
Oregon
He needs the air bags! As for the sway bar I find it hard to believe there's nothing out there that will fit. As I've said several times on this forum the big wig sway bar was the single best mod I have but without the air bags it just won't work. As for what jmtandem says... no the sway bar will not "eliminate" sway but the difference is day and night. The bilsteins are also a good investment.
2008 Dodge Ram 6.7 Laramie SRW SB
2012 Keystone Passport 26BHWE
2009 Lance 830 with Tent foldout
20' North River Seahawk Boat
2005 Honda VTX1300
narcodog
Georgia
halibutman214 wrote: He needs the air bags! As for the sway bar I find it hard to believe there's nothing out there that will fit. As I've said several times on this forum the big wig sway bar was the single best mod I have but without the air bags it just won't work. As for what jmtandem says... no the sway bar will not "eliminate" sway but the difference is day and night. The bilsteins are also a good investment.
The sway bar won't mount because the AB's are mounted n the same area.
halibutman214
Oregon
I understand this but as I said, I can't believe there are NO sway bars that will fit this rig. In any case the air bags are needed.
kohldad
Goose Creek, SC
Since he arleady has the air bags installed, I would just make sure they are plummed seperately and give it a try. Don't forget to try around with different pressures to see which works best providing enough support but not increasing too much sway. I would try 20# increments then fine tune.
If he isn't happy with the sway, then drop the air bags to a couple of pounds and see if he can handle the sag. If so, then drop the bags and add the bar.
Why start changing things before he even sees how the rig handles.
Photo Albums
2004.5 Ram 3500 4x4 Quad-Cab SRW CTD 6-spd, XD9000 winch
2004 Lance 815 (an upgrade from my prev 2005 35' fiver )
DW (homemaker), 1 DD @ Clemson in Civil Eng (Dec 2013) w/SIL, 1 DD Tech Grad (home but employed), 2 DFs (meow)
