Dale.Traveling
Newport News, VA
I have an self point antenna on the roof of the coach that about 75% of the time when park it's view of the satellites is obstructed. To get around this I have an antenna on a tripod I set up and manually aim. I connect the ground antenna to the CG cable TV input on the side of the coach. At this point I have to pull the satellite receiver out of the cabinet, disconnect the roof antenna and connect the second antenna to the input of the receiver to regain satellite TV if I wish.
Is there away to avoid having to swap inputs to the receiver such as an electronic or manual switch that is compatible with the signal from the antenna and DC power being supplied by the receiver?
My receiver is a Dish VIP222K with two inputs but the second input is for the second TV for independent channel surfing, at least as I understand how it works.
2006 Hurricane 31D aka 'Moby' the Whale
FCC(SW) US Navy Retired 1980-2003
Stella my Navigator
Bogart the All American RV Dog
and
Cocoui waiting for me at the Rainbow Bridge
rvrepairnut
bc
Dale.Traveling wrote: I have an self point antenna on the roof of the coach that about 75% of the time when park it's view of the satellites is obstructed. To get around this I have an antenna on a tripod I set up and manually aim. I connect the ground antenna to the CG cable TV input on the side of the coach. At this point I have to pull the satellite receiver out of the cabinet, disconnect the roof antenna and connect the second antenna to the input of the receiver to regain satellite TV if I wish.
Buy a good quality AB switch.works good
center plug is out to receiver A = cable inlet+ portable dish antenna and B = sat receiver
MountainAir05
New Mexico
you need a Video Distribution Center switch. Then you just hook up everything a push a switch to connect what you want to used.
bugs53
Jacksonville, Fl
Dale, that is one great looking dog. I have some thoughts and a few photos of my set up. I will send you a PM and an e-mail address. You can let me know if interested.
Bugs
bugs53
08 Tiffen Allegro, Wrangler Shahara.2dr std, Us Gear Breaking
Mango 3speed cruisers
Cookie. Springer Spaniel
zman-az
Northern AZ
My smart phone has a compass and before I park I get it out. I know where I live the dish needs to point southeast so I confirm I have line of site before I drop anchor.
Wherever I happen to park
You will need... (Fore each LNB in on your receiver(s) a short length of RG-6 cable 2-3 feet is more than enough
A low cost Antenna switch such as the RCH VH-71 (a buck at the Google store last time I googled "antenna switch")
A goes to the roof mount up above
B to the input in the side of the RV down Below
Remaing terminal to the LNB in on the receiver
Now.. With the switch in A hook up ground mount,, slide switch to B and if it's a DISH aim and check switch,, Direct RESET and aim.
When you go to unhook slide to A first (That way the receiver is not connected to the wires you are playing with, NO chance of a short)
It works, I do it. (Or did it)
Kiwi_too
Western, WA
If you intend to use cable at any time you will need 2 AB switches. I can send the wire diagram if you PM me.
May God bless your travels
Me, The Wonderful Wife
and two Spastic Border Collies
U.S. Army Retired
2004 Coachmen Aurora, 3480DS
2007 Saturn Outlook, FROG
Dale.Traveling
Newport News, VA
MountainAir05 wrote: you need a Video Distribution Center switch. Then you just hook up everything a push a switch to connect what you want to used.
Won't work. The sat receiver needs to pass both DC power and LNB switching commands to the antennas. The standard RV video distrubution switch blocks the signal.
Dale.Traveling
Newport News, VA
I wondering if a DiSEqC 2 X 1 Switch will work. Both antennas have a SW21 in them to allow for multiple LNB configuration and to the receiver they are functionally the same. Since I'll only be using one or the other antenna and not both at the same time I think this might be a solution.
Rich D.
New England
wa8yxm wrote: You will need... (Fore each LNB in on your receiver(s) a short length of RG-6 cable 2-3 feet is more than enough
Make sure you get a switch that is capable of handling the satellite signal (High Isolation type). Many cheap, slider type, A-B switches will drastically degrade the signal or not pass it at all.
Rich D. Wanderlodge M450 LXi
