RV.Net Open Roads Forum: Screen door mod
JBarca
Dublin, Ohio, USA
Posted: 03/30/12 07:04pm Link  |  Print  |  Notify Moderator
EMPIRE LI wrote:
Help I went to cut the the lexan to cover my screen door used the finest jig saw blade I could find and the lexan cracked.
Hi Empire,
Something does not sound right. Did it say GE Lexan polycarbonate on the label?
We put real 1/4" Lexan in a press break at work and bend it 90 degrees and it does not crack....
Now plexiglass will crack looking at it sideways... The 1st camper I used plexiglass and snapped a panel in 1/2. The next camper I used real lexan and even sawed it with my radial arm and saber jig saw using a fine wood blade.
Here see my post
Lexan Screen Door Panel Mod 101 (Lots of pics and long)
Good luck and hope this helps
John
John & Cindy
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10
CC, SB, Lariat & FX4 package
21,000 GCWR, 11,000 GVWR
Ford Tow Command
1,700# Reese HP hitch & HP Dual Cam
2 1/2" Towbeast Receiver
2004 Sunline Solaris T310SR
(I wish we were camping!)
christopherglenn
a little over an hour from Yosemite
Posted: 03/30/12 09:56pm Link  |  Print  |  Notify Moderator
I use a metal cutting blade, the more teeth the better, and I find it works faster and cleaner cold, but hot it tends to melt its way through the material.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
NorthernLimits
Michigan
Posted: 03/30/12 10:05pm Link  |  Print  |  Notify Moderator
Couldn't have been true lexan. I have cut lexan in a pinch with a blade designed for trimming tree branches in a sawzall, 50 miles into a trail in the Canadian woods.
happy-2
calif
Posted: 03/31/12 09:43am Link  |  Print  |  Notify Moderator
Hello, First of all why are you using that to cover your screen door?
RVTravler
Posted: 03/31/12 06:28am Link  |  Print  |  Notify Moderator
Believe it or not, I used a hack saw blade. Worked for me.
Playtime II
No. VA
Posted: 03/31/12 08:36am Link  |  Print  |  Notify Moderator
I just used an old plywood blade in my circular saw (forward, not backwards) and it cut .093 just fine last week.
Playtime IV
2006 HR Scepter 42DSQ
happy-2
calif
Posted: 03/31/12 09:45am Link  |  Print  |  Notify Moderator
Hi, frist of all why are you covering your screen door?
BillyW
North ID
Posted: 03/31/12 10:36am Link  |  Print  |  Notify Moderator
After having the big box store cut mine to size, I rounded the corners with a band saw, then smoothed them with a belt sander. happy-2, it's awesome to be able to leave the door open on those crisp mornings or hot afternoons without losing all your heating or cooling. I went the next step and added a magic mesh screen door. Now I have a door, storm door, and screen door.
Now back to your regular programming.
'97 F150 4X4
'04 Pioneer 18T6
lclevel
Norwood, La.
Posted: 03/31/12 01:05pm Link  |  Print  |  Notify Moderator
Does anyone have any pic's they could post? I'm interested in this mod myself. Thanks.
NorthernLimits
Michigan
Posted: 03/31/12 10:04am Link  |  Print  |  Notify Moderator
To keep the cool in but still have the big door open to be able to see out.
Or to protect the screen from pets.
