RV.Net Open Roads Forum: Truck Campers: Seal between cab window and camper
 > Seal between cab window and camper
Jamm3r
Minnesota
Posted: 03/30/12 04:20pm Link  |  Print  |  Notify Moderator
Does anyone have a seal of some kind between the truck cab and camper window so you can open both windows and have (say) the cat wander back and forth? How does it work? Where did you get it?
1971 Cayo C-11 truck camper, 2010 Airstream Classic, 1997 Chevrolet K2500, 2004 Chevrolet Suburban 2500 8.1.
Gripnriprod
Alaska
Posted: 03/30/12 04:53pm Link  |  Print  |  Notify Moderator
Here's one: Boot
'11 GMC 3500hd SLT DRW D/A 4x4 Spray-in, Air Bags w/comp & controls, TL, Superhitch, 48" Supertruss, 9.5t Warn, front rcvr, Fox Shocks, '11 AF 1140, DB, AC, Gen, Solar, Thermal Windows, Wardrobe, Rear & Side Awnings, 18' Lund/40hp Honda 4 stroke
cewillis
Tucson, az, usa
Posted: 03/30/12 05:40pm Link  |  Print  |  Notify Moderator
And how fast does it wear the paint off the truck?
Cal
ILLTravler
New Lenox, Illinois
Posted: 03/30/12 05:59pm Link  |  Print  |  Notify Moderator
I USED A CAR TIRE INNER TUBE AND MADE A CLOTH COVER THAT ZIPPED AROUND THE TUBE. MANY YEARS OF USE, NEVER ANY ISSUES WITH PAINT.
MADE THE CAT VERY HAPPY!!
11 Chevy 3500 long bed EXT CAB 6.6 4X4
2005 Host 8.6 Bachelor SS TC
97 BRYANT BOAT
Camper_Jeff_&_Kelli
Seattle
Posted: 03/30/12 06:43pm Link  |  Print  |  Notify Moderator
I could not find anything in the stores for this purpose so I made my own out of 3" foam, duct tape, and spray contact adhesive. Cost was about $30.00 and a couple hours time. I like it, the Cat likes it, Kelli likes. Everyone's happy. It was easy to make. I do fit a plastic garbage sack over the top for a water proofing for the foam.
Camper Jeff and Kelli's Blog!
Photog101
Garden City, Michigan
Posted: 03/30/12 07:39pm Link  |  Print  |  Notify Moderator
I have one from years ago ... and it still works. It has the fill valve on the outside and only takes 4-5# of air pressure. I had it on my old truck and camper for years and it did not rub off the paint.
I also had one that fit on the roof with an outside fill valve, but it disappeared. Wish I could find another one. I also found that after I put the one on the roof, that I got just a touch better gas mileage.
Both of them worked better than the cab over shocks that had to be replaced twice in the 5 years. I had that truck and camper for 12 years and the air cushions worked much better.
Combat Vietnam Veteran Support our troops for serving our great country.
1997 Veri Lite RL1200 on a '02, K3500, CC, DRW, 8.1L, Allison, 4.1 gears, Bridgestone 225/70R19.5 tires.
