RV.Net Open Roads Forum: General RVing Issues: Do RV Covers Work
 > Do RV Covers Work
ScottG
Bothell Wa.
Posted: 03/31/12 10:44am Link  |  Print  |  Notify Moderator
I bought one for my then new TT. It was a lot of money so I hope it would be worth it. It has been. My TT doesn't weather during our long winters here. It doesn't get wet or suffer the UV damage. In the spring when I uncover it, it still looks clean and frankly after 8years, it still looks new. I also noticed that the water traps I put in it don't get nearly as much water in them if it's covered up (no it doesn't leak anyplace). Keeping the weather off it extends the life of the unit indeffinately.
Scott, Grace and Wesly
H0NDA eu2000i
sc3283
St Louis
Posted: 03/31/12 09:23pm Link  |  Print  |  Notify Moderator
I uncovered mine yesterday and it looks like its just been washed(almost)
No streaks, NO UV damage and beings the cover is almost waterproof...its not been wet with the rain and snow throughout the winter(yes I have gone out and checked underneath during or after a rain..and its almost 100% dry). I will always cover mine...only makes sense to keep as much weather off of them as possible in the off season. I do use an RV specific cover...not the cheapy tarps from the home stores
* This post was edited 04/05/12 10:31pm by sc3283 *
04 D-Max Crew Dually
96 Monaco Dynasty 36'
axkick23
Riverside
Posted: 04/06/12 09:37am Link  |  Print  |  Notify Moderator
I had a RV cover and it was destroyed with in a year of getting it. I would not recommend them. They are not that strong and will rip easy in the wind. Not worth the money.
down home
south
Posted: 04/06/12 06:39pm Link  |  Print  |  Notify Moderator
We purchased the best cover they sold.
Padded the corners of the fifth wheel.
We mad moisture build up during the 2 winters and some green stuff.
We constantly had to snug the straps under the bottom. Not too tight but every time the sun shined it seemed to stretch.
Wind also stretched it. Spring of the second year the wind was unusually brisk for this area. Not real high but high enough to stretch the fabric and make tightening the straps, to keep the cover from flapping often. The wind and heat and moisture caused it to tear at the corners that spring before we took it off. RV stayed dry inside. Neighbor kept his own after it was a little warm Heat buildup caused damage to wall paper and plastics inside.
My opinion you are better off with a hard canopy of or building, that also keeps the elements off the sides and tires, or ultimately a closed building.
tracyb-oh
Cincinnati,Ohio
Posted: 04/06/12 07:48pm Link  |  Print  |  Notify Moderator
We have covered ours every winter for 10 years now. Also covered the tires. Our storage lot is next to an active railroad line so we get lots of diesel exhaust from the locomotive. It really helps to keep our motorhome clean. Only trick to put it on is we watch for a day with a slight breeze as it helps us get the thing airborne a little to help put the cover on. Looking around out storage lot which has about 75 various RV's parked there I would say about 75% have covers, about 5 have blue tarps and the rest are mostly junk that the owners don't care.
Tracy and T
Jayco 2001 Class C 3150J Designer
2007 Honda CRV
"The Girls" Honey and Crystal our dachshunds
Ron3rd
Upland, CA USA
Posted: 04/07/12 06:35am Link  |  Print  |  Notify Moderator
Overall we like using the cover as it keeps the rig very clean. They can be a bit of a PITA to put on and take off, but once you develop a method, you can do it in about 5 minutes. Downside is the good ones a very expensive. I've had 2 of the cheaper ADDCO covers with the white top. About 300 bucks. This type last about 3 years max IMO.
The Sunbrella fabric covers are supposed to be the best, but they run about a grand for my size rig. Our last one got tore up in the high winds we had for about a week here in So Cal so we'll be getting another one soon. I'm gonna look at Goldline this time.
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
phil crouch
NW Oregon
Posted: 04/07/12 08:19am Link  |  Print  |  Notify Moderator
Nothing works better than a very good wax job before putting it away for the winter or summer.. JMHO of course..
Highway 4x4
La Verne, Ca
Posted: 04/07/12 10:16am Link  |  Print  |  Notify Moderator
Here in So Cal I have covered my TT as much as much as I can with an ADCO cover and have purchased 3 over ten years. I don't get any wind here. My TT still looks great because of it. But I probably won't be covering it any more, I'll just wax it more often. In the desert you're going to get wind that will probably cause more dammage with a cover than not. I would say put the money for a cover toward keeping it waxed and the metal garage. Two years won't kill it in the sun with wax. Might want to cover the inside of the windows to protect inside from UV damage.
RCMAN46
NorthWest
Posted: 04/07/12 12:08pm Link  |  Print  |  Notify Moderator
If you have dual pane windows do not cover them on the inside. The heat build up will destroy the gasket seal between the window panes.
msmith1199
Central, CA
Posted: 04/07/12 01:18pm Link  |  Print  |  Notify Moderator
Dick_B wrote:
Search this Forum for `RV Cover' and read the many responses already posted including my recommendation for covers to protect against the sun.
The argument against covers is that the dealers don't cover the rigs in the yard but I think this may be for two reasons: 1. they don't want to spend the money; not that it wouldn't keep the roofs cleaner and 2. there usually are no trees in the yard that drop leaves on the roof. A few maple leaves can make a mess!
The dealers don't cover them because you can leave an RV out in the sun for a few years without noticing it. But leave it in the sun for five or more years and the sun takes its toll. My only opposition to covers is they are a royal pain to put on and take off. I used to cover my motorhome and then I quit because I found myself not wanting to take off for the weekend because it was too hard to take the cover off and put it back on.
2004 National Tropi-Cal T-350, Class A, Triple slide, 330 HP Cat DP.
2006 Dodge Dakota 4x4 or
2002 Harley FLSTF Fat Boy on a Trailer or
2004 Polaris Quad on the Trailer
 > Do RV Covers Work
