RV.Net Open Roads Forum: Fresh water regulator & inline water filter
 > Fresh water regulator & inline water filter
ajlamon
Fort Worth, Texas
Posted: 03/31/12 04:22am Link  |  Print  |  Notify Moderator
I'm new to the RV world and have a couple of questions relating to freshwater pressure regulation and filtration for city water hookup. I've read that some pressure regulators sold in RV Outlets do a poor job of regulating proper water pressure and in some cases restrict the flow of water as to make them impractical. Is this true? What is a recommended safe pressure for RV plumbing. Also, many of the inline filter specifications are 1 gal of water/per minute flow rate---is this enough for average RV usage and to fill the freshwater tank as required? Is there a recommended type of water filter that seems to work better than others (good filtration).
I appreciate any help from you experienced types...
edatlanta
Panama City Beach, FL
Posted: 03/31/12 04:32am Link  |  Print  |  Notify Moderator
Check out Here. All you ever need to know about RV water filters/pressure and flow regulators, etc.
Ed
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, TTT/Schefenacker Towing Mirrors, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
wolfe10
Posted: 03/31/12 09:21am Link  |  Print  |  Notify Moderator
Disagree on the "blue inline hose filter IF you are filling your potable water tank.
Most of the sealed inline filters contain charcoal. Charcoal will remove chlorine. That is fine if you are going to immediately use the water, but NOT a good idea if you are going to store the water.
Better is to use a fine-micron (I use a 5 micron) sediment only filter going into the coach and then a charcoal-based filter on a drinking water spigot.
The other issue with the sealed inline filters is that many are not bacteriastatic. They have nothing to inhibit the growth of "gremlins" that you are then filtering your water through. The whole house type filters with replaceable elements allow you to safely store the filters between uses. If in a dry climate, just let the filter dry out. If in a humid area, put the filter in a Ziploc and throw it in the freezer.
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
RCtime
So. Calif.
Posted: 03/31/12 09:25am Link  |  Print  |  Notify Moderator
Highly recommend the Watts 263A, follow Ed's link.
I like my everpure filter with its drinking water spout on the sink, however its not total RV water filter. But of course thats what my coach came with, so cant compare.
Ron
2002 34HD Winnebago Journey DL, Cat. 330/freightliner
2004 Honda CRV - Garmin 1490t
Great wife & Cavalier King Charles Spaniel
TT/N
donhoward49
Portland, Oregon
Posted: 03/31/12 04:54am Link  |  Print  |  Notify Moderator
I just buy both items at Camping World, brass regulator and the blue inline hose filter..Any real concerns buy bottled water.
SantaNSC
Salley, SC
Posted: 03/31/12 09:00am Link  |  Print  |  Notify Moderator
I'd buy 2 of the brass regulators. They do go bad and plug up.
PeppyPilot
NW Chicago Suburbs
Posted: 03/31/12 09:55am Link  |  Print  |  Notify Moderator
We have a water regulator on board, but rarely use it. The only time I can think of was at Yellowstone, where water pressure was very high.
We use an inline water filter (yes, the charcoal type) and it, in effect, is an adequate pressure regulator unless the pressure is really quite high.
We are starting our 9th year with our unit and the plumbing still works perfectly - no leaks or other problems, so this must be working pretty well.
We do drain, flush, and sanitize the fresh water tank at least annually and we only use bottled water to drink.
Our choices and they work well for us.
CJ and Pepe
2003 Itasca Suncruiser 33V
Workhorse W-20 chassis
2004 Jeep Liberty Limited w/Blue Ox
ScottG
Bothell Wa.
Posted: 03/31/12 02:58pm Link  |  Print  |  Notify Moderator
If you buy a regulator, make sure it says "High Volume" and you will not suffer any problems with flow.
Scott, Grace and Wesly
H0NDA eu2000i
Tinstar
McKinney, TX
Posted: 03/31/12 11:06pm Link  |  Print  |  Notify Moderator
Mine is a Watts whole house regulator mounted in the water bay. I use a non-burst host to feed the water supply. After the regulator, I put in the canister water filter with the filter like Brett talked about up above.
Never pass up a chance to go somewhere
donhoward49
Portland, Oregon
Posted: 04/02/12 06:53am Link  |  Print  |  Notify Moderator
Wolf10, Thank You. I learn something new everyday. I see that C.W. has a culligan hose filter for Odor/Sediment/Taste.. then I need a drinking water filter at the sink, thats been on my list i just have not gotten around to it.
Question. on storing the hose filter, I have always just put it in a zip bag in the bay, should I let it air out to prevent "gremlins"
How about the sink filter setting with water, several weeks between trips?
Don
* This post was edited 04/02/12 07:56am by donhoward49 *
