kingrick5
Canada
Hi bikendan.
We checked the tow capacity on the escape (5000 lbs) before we bought the trailer (3800 Lb) and had the hitch on the escape switched from the factory installed 3000 lb to a 5000lb unit with stabilizer bars and a transmission cooler. The installer is very reputible. Hope we're ok!
Giant Tiger
Pembroke, Ontario
Trailer Life's 2012 Towing Guide shows the Ford Escape with a 3.0 V6 and a towing package rated to tow 3500 lbs maximum. I'd visit Can-Am Rv on the web, get their phone number and call Andy Thompson for some advice. He is the "Towing Guru" here in Ontario. Their dealership is located just outside of London, Ontario
Lou
2013 Sol Aire Eclipse 269 BHDSK Travel Trailer by Palomino arriving May 14th,2013!
Nights camped in 2012: 32
kingrick5
Canada
Thanks Lou. Just e-mailed Andy.
bikendan
Napa, Cal.
kingrick5 wrote: Hi bikendan.
there's no way an Escape has a 5000lbs. tow capacity!
whoever told you that, lied. why didn't you check with the Ford dealer? they would have set you straight.
it has had a 3500 tow capacity for years.
larger SUVs with the bigger 4.0 v-6, have a 5000lbs. tow capacity, like the Explorer. but not the Escape.
and just because they put a 5000lbs. receiver, doesn't change what the Escape can tow. it means it's rated for that weight but has nothing to do with the vehicle it's put on.
you've been sadly misinformed.
and if you decide to go the Can-Am way, will they cover you if you're in an accident and the investigation shows you exceeded Ford's tow specs and you get sued?
Dan- Firefighter , Shawn- Musician/Entrepreneur , Zoe- Faithful Golden Retriever , 2007 Chevrolet Avalanche LS, 2007 Rockwood Roo 23SS w/Equalizer and Prodigy, and 5 Mtn. bikes and 2 Road bikes
kingrick5
Canada
You're right Sam. The tow cap on the escape is 3500Lbs. We were mislead by the sales rep. and told if we went to a no.3 hitch (5000lb capacity) we would be fine. We went to a hitch dealer and had the conversion done (another $1600).
We will be calling the dealer tomorrow morning.....Wish me luck!
kingrick5
Canada
Hey folks;
Checked in with Andy Thompson (Towing Guru). He straightened everything out. The trailer weight range is 3500lbs. However the GCWR (Gross combined weight rating) is 7140lbs. He said, with my new type (3) hitch, brake control, stabilizer bars and trans cooler, I am good to go!
bikendan
Napa, Cal.
kingrick5 wrote: Hey folks;
you haven't said which model Kodiak you bought. is it the 160 model?
Chuck_S
Broadview Hts, OH, USA
I thought this thread was about electrical problems....
-- Chuck
'06 Roo 23SS behind '07 Expedition out of Cleveland
Our Photo pages
bikendan
Napa, Cal.
Chuck_S wrote: I thought this thread was about electrical problems....
-- Chuck
it's my fault, Chuck. when i saw the OP was going to pull a full height HTT with an Escape, i had to ask. and then when the OP posted that the Escape had a 5000lbs. tow capacity, i got worried for them.
