RV.Net Open Roads Forum: Fifth-Wheels: Front Landing Gear Uneven
 > Front Landing Gear Uneven
Kerbouchard
Parker, Colorado
Posted: 03/31/12 05:42pm Link  |  Print  |  Notify Moderator
Have a 2003 Jayco Qwest. The front gear are a manual crank. The right one cranks out faster than the left. They are uneven now. The right one is out about 6 inches farther than the other one. Not sure how this could happen or how to correct it. Any advice appreciated.
Looking for a Fiver
2003 Dodge 2500 Diesel
B & W Underbed hitch with a B&W Companion
Prodigy brake controller
Timbren Aeon Suspension Enhancement System
skipnchar
Topeka or somewhere else
Posted: 03/31/12 06:02pm Link  |  Print  |  Notify Moderator
Isn't there a release to allow them to drop to the ground before cranking them? That should self level them before each use.
Kerbouchard
Parker, Colorado
Posted: 03/31/12 06:09pm Link  |  Print  |  Notify Moderator
It is not the adjustable end that is uneven but the part that actually cranks into and out of the frame.
Dr Quick
M'boro, Tn
Posted: 03/31/12 06:21pm Link  |  Print  |  Notify Moderator
Which one is uneven? If it is the right curb side one, could possibly be a pin sheared, and it is just friction allowing it to turn a little, and not keep up with left side.
Dr Quick
johntank
Oxford, Ms 38655 USA
Posted: 03/31/12 06:46pm Link  |  Print  |  Notify Moderator
Like Dr Quick said it is the shear pin on the left side as you are looking at the trailer, The best way to fix this is disconnect the crossbar between the two jacks by taking the pins/bolts out on each end then you can adjust the leg that is lower/higher to corrospond with the other, you can then replace the crossbar useing grade 2 bolts of the size needed just use lock nuts so they want come loose.
Hope this helps
Kerbouchard
Parker, Colorado
Posted: 03/31/12 07:17pm Link  |  Print  |  Notify Moderator
It is the passenger side (right,curbside, camper door side) that is out further. The handle is on the driver side (left). I am not sure if one is coming down faster or they are just misaligned. The connecting bar seems fine. Could I disconnect the bar between the two legs, crank the left one out the same as the right then reconnect it? Just bought the thing did not notice it till I got it home. Thought not having an electric would be one less problem.
jetboater454
Camping or home
Posted: 04/01/12 04:35am Link  |  Print  |  Notify Moderator
Yes you can just disconnect the bar and turn one until they are the same length,reinstall the bolt and nut and your good to go.If over time one gets longer again,check the teeth on the gears.Usually the top cover just pops off.
"If momma not happy ....Who cares.I have my TH AND my toys .
2007 Gulfstream Endura Max 40
2001 Polaris Ranger 4X4
Mod Pics
Irelands child
Upstate New York
Posted: 04/01/12 05:48am Link  |  Print  |  Notify Moderator
johntank wrote:
Like Dr Quick said it is the shear pin on the left side as you are looking at the trailer, The best way to fix this is disconnect the crossbar between the two jacks by taking the pins/bolts out on each end then you can adjust the leg that is lower/higher to correspond with the other, you can then replace the crossbar useing grade 2 bolts of the size needed just use lock nuts so they want come loose.
Hope this helps
Just a quick question - why would you use a Grade 2 bolt on anything that has a shear action? At 74,000 psi minimum tensile strength they are approximately 50% of the tensile strength of a Grade 8. That myth, if that's why you suggested a Gr2, that Gr 8 bolts in shear fail easily is just that
bpounds
Whittier CA
Posted: 04/01/12 10:09am Link  |  Print  |  Notify Moderator
Irelands child wrote:
Hope this helps
Because the shear pin is a protection device for the drive system. You WANT the pin to shear if there is an overload.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
christopherglenn
a little over an hour from Yosemite
Posted: 04/01/12 12:03pm Link  |  Print  |  Notify Moderator
Shear pins act as fuses. Better to break a .29 part then a $50 part.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
