RV.Net Open Roads Forum: Extension Hose To Attach Portable Grill To Camper Gas?
 > Extension Hose To Attach Portable Grill To Camper Gas?
Don & Linda
Western PA / Cape Cod
Posted: 03/31/12 10:25pm Link  |  Print  |  Notify Moderator
I carry a spare #20 bottle and also use the camper's outlet at times.
Never use the small disposable type bottles. Too expensive and we are too darn Yankee. (read cheap)
My gas outlet, and I think most camper outlets are like a "thread in" #20 propane bottle type connector.
Which hose setup I use, depends on my site and/or mood.
I remove the grille's regulator when attaching to the camper's outlet, and reattach the grille's regulator to use with my spare #20 bottle.
Only regulate the gas pressure once and check your connections with a soapy solution for leaks.
Stay safe and enjoy, Don
Sorry if this post seems long, I lacked the time to make it shorter.
almost quote from S.L. Clemens
Don & Linda
1st RV UL EMS 4s Dome
2nd RV 21' AMF Scamper TT PV D300 Dodge
3rd RV National Seabreeze 133LX w/Demco Dolly
4th RV Jayco 2450 5TH PV Ford F-250 SD
cm11599ps
Long Island
Posted: 03/31/12 10:34pm Link  |  Print  |  Notify Moderator
Great, so then that means all I would need is http://www.rvtruckparts.com/ProductDetail.asp?PID=26431&DID=37&CID=323&DealerId=&SID=12
Sound good? Just plug one end into the gas output on the camper and the other into the regulator on the grill.
usmc616
Orange County, New York
Posted: 03/31/12 11:22pm Link  |  Print  |  Notify Moderator
That item looks like it goes between the TT's propane tanks and the TT's regulator.
SEMPER FI
Joe,Joyce 4 kids & 3 dogs
2004 Ford Excursion LTD 4x4 V-10 3.73 Gears, Hellwig Swaybar, Bilstein Shocks & Steering Stabilizer, Roadmaster Active Suspension, Super Duty Tow Mirrors
Reese Dual Cam & Prodigy Brake Controller
2010 Jayco G2 32BHDS.
cm11599ps
Long Island
Posted: 04/01/12 07:53am Link  |  Print  |  Notify Moderator
Lol, it seems I'm getting conflicting answers.
bukhrn
Lanexa, Va
Posted: 04/01/12 08:28am Link  |  Print  |  Notify Moderator
Some use an elbow,CamCo uses a T, as you can see, it goes between the tank outlet & the regulator,http://www.rvpartsoutlet.com/popup_image.php?pID=12189&image=0
this is how I hooked mine up, no problems.
2007 Forester 2941DS
2005 KIA Spectra
falconman
On The Road!!
Posted: 04/01/12 08:47am Link  |  Print  |  Notify Moderator
The answers you have gotten are all good but it doesn't sound like you understand how your LP system works and that could be dangerous. The large LP tank on your trailer provides high pressure unregulated gas ranging from 10 psi to 120 psi. In order to use it inside for heating cooking, etc it must be brought down in pressure. You probably have a two stage regulator which is fed by the main tank. It is two regulators attached together The first regulates the tank pressure down to about 10 psi, the second down to about 1/2 psi (11-14 inches WC) which is what enters your trailer and includes the grille quick connect on the side of the trailer. Attaching a grille that already has a regulator on it, namely the ones that use the small bottles, will not provide sufficient gas to the grille. They will work, but at a reduced heat. So to use those grilles you must remove their regulator. The Weber series seem to be the most popular and easiest to modify.
Now if you don't wish to or cannot remove the regulator then a device like the Extend a Flow comes into play. It fits between the trailer LP tank and regulator. So it provides high pressure unregulated gas to the grill, like the small bottles, and uses the grilles regulator to control gas flow.
The real danger is you just never connect high pressure gas to a non regulated device, you will then have a blow torch.Internet advice is helpful but I would suggest you check with a certified propane location to verify that what you want to do is safe.
Ron3rd
Upland, CA USA
Posted: 04/07/12 06:46am Link  |  Print  |  Notify Moderator
cm11599ps wrote:
bob213 wrote:
You need something like this:
extend a flo
Is that something I would plug into the gas output on the camper or to the actual tank?
I have the extend a flow kit but that is NOT what you want since you already have the quick disconnect on your trailer. The Extend A Flow kit is for coming directly off your trailer tank with the supplied Tee adapter. You don't need that.
One way to make this simple is to remember you only want one regulator in the line to the bbq. Your propane port on the side of your trailer comes off the regulator in your trailer. Most all bbq's come with a regulator. That would give you "2" regulators in the line which might provide too low of propane pressure.
Here's what I would do; If you don't have a bbq already, get something like the Weber Q series and remove the Weber's regulator. Next, get a quick disconnect propane hose to fit the port on your trailer along with the necessary fittings to adapt the hose to the propane inlet to the Weber, which will now just be a threaded hole because you removed the regulator. That's what most folks on this forum have done and if you do a search you fine a lot of posts with pics, description of fittings, etc.
The other option like posted above is to just carry a small portable propane tank and hook up to that.
HERE'S A HELPFUL LINK
In the link I posted, scroll down to the post by Bob Landry. He lays it all out for you with respect to what you need to do. Very simple actually.
* This post was edited 04/07/12 06:56am by Ron3rd *
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Honda EU2000
Hybridhunter
At home
Posted: 04/06/12 06:20pm Link  |  Print  |  Notify Moderator
If you want a great RV BBQ. Go out and grab a Weber Q100. Unscrew the regulator, go to your local hardware store, and grab the correct fittings (1/8 npt X 3/8 npt and a 1/8" npt pipe nipple, I think). Thread it all toegther and get a Campgrill quick connect by 3/8 extension hose.
Voila - A better grill (albeit small) than most folks have on their deck at home.
Ignore the know it alls who say it won't work and have never tried it. It works, and the Q will hit 600 degrees. You can sear a steak, cook potates, and BBQ a burger as well as any grill. The Weber rocks, and mostly because the cast iron grates.
Don & Linda
Posted: 04/03/12 08:11pm Link  |  Print  |  Notify Moderator
cm11599ps wrote:
We never use the small disposable type bottles. Too expensive and we are too darn Yankee. (read cheap)
Wrong. If you use the camper side outlet and the grille regulator in unison , that's two regulators...
Read falconman and webslave's offering. They do a fine job of clearing up what you found confusing about my post. If your still confused, please seek professional help. (propane professional, meant)
Let us know how you make out. Don
webslave
Clearville, PA
Posted: 04/01/12 09:40am Link  |  Print  |  Notify Moderator
If you are going to try and use your grill "stock", and it has a built in regulator, you cannot use the quick connect on the side of your trailer. Can't be done (effectively) no matter what connector assembly you use. If you are going to use the grill with its own regulator, you have to "T" into the high pressure line between the tank and trailer's own regulator assembly so that you get unregulated LP to the grill. Can be done and many people use said adapters, the most popular being Stay a While or similar, either the whole kit or just the "T" and you supply your own hoses.
If you want to use the low pressure "quick connect" fitting on the underside of your trailer with your grill, you can't use a grill with a regulator still attached. You either have to buy or have a grill designed for RV low pressure use (a lot of trailers come with one) that already has the regulator removed or you have to have a grill that is built such that the regulator is separate from the gas control valve and can easily be removed...the Weber Q series of grills are one such and are very popular. Easy to convert, well made, compact and they cook quite well.
Here's a post the I had put up on the 5ver page concerning the conversion:
Weber Conversion
Here is a site that sells any of the above pieces of "conversion" equipment you might need, from the Stay a While type "T" connectors and hoses, to the conversion pieces you might need if you are going to remove the regulator from your current grill (you don't mention the brand of new grill you have; it may or may not be a candidate for conversion):
Conversion or High Pressure "T" supplies
Again...if you are going to use your grill with its regulator attached, you have to tap into the line between one of your supply tanks and the trailer's regulator or you have to remove the grill's regulator in order to convert it to use the low pressure quick connect on the trailer.
My 2 cents, your mileage may vary...
Don
Bronwyn
3 Cats - Coco, J-Lo and Ragamuffin
2011 Keystone Cougar 318SAB
2011 Ram 2500 Longhorn CTD HO
Built in brake controller and exhaust brake
Tri Glide TrailAir Pinbox with a B&W Companion Hitch
