vandave
jamestown, ohio
I read an advertisement about TT roofs being coated/replaced with rhino truck bed lining material. Never heard of such a thing. Does anyone have first hand experience with that process? I've did do some searching on other sites and a place in Florida uses a Dupont similar product but the cost is over $9,000 for a 30' TT and I can't imagine someone spending that kind of money for a roof replacement. Other concerns were the weight of the material on the roof and how good would it contact with the current roof or did the current roof have to be completly removed to the wood surface. Anyone know someone who has actually had their roofs done this way?
Vanda and Dave Ludwig (Vandave) Spoiled King Charles Spaniel, Ultra spoiled Cock-a-phoo, '12 2500HD, 4WD, CC, SB, 6.0, 4.10, 30U Arctic Fox, Equalizer.
JIMNLIN
out here
I asked my a local truck and stuff type dealer about his spray on Rhino material on a large 8" x 20'-30'+ RVs roof. He gave me this deer in the headlight stare and made several comments. His first comment was why would anyone want to add that much more weight to the RVs roof. His second comment was "your kiddin' right".
'97 Park Avanue 28' 5er 11200 gvwr two slides
gbopp
The Keystone State
JIMNLIN wrote: I asked my a local truck and stuff type dealer about his spray on Rhino material on a large 8" x 20'-30'+ RVs roof. He gave me this deer in the headlight stare and made several comments. His first comment was why would anyone want to add that much more weight to the RVs roof. His second comment was "your kiddin' right".
Did he say how much actual weight the Rhino material would add?
mwebber78
New England
I can't see applying it to a TPO or EPDM roof but a fiberglass roof, well maybe. As far as weight - I can't imagine at 1/16 to 1/8" thick it would be that heavy.
2013 Jayco Eagle 334RBTS
Disclaimer for the daft: Don't confuse my opinion with facts.
hilandfrog
Montana
at about ~8 lbs per gallon, how many to coat the roof?
Repo
05 Tundra 4x4
1976' SIX PAC, cut to size and function.
$800 1977' Road Ranger, not yet road worthy (AUG '11')
DE88ROX
West Michigan. The other West Coast
8 lbs a gallon. Even if it took 4 gallons, once you spread that out over the roof the weight wold be minnimal.
Your home fridge weighs more than a typical water bed per sq foot simply because of the WD. Its the simple principal.
TV- 2010 GMC Sierra Z71 EXT. cab
TT- 2012 Starcraft Autumn Ridge235fb
skipnchar
Topeka or somewhere else
I do not but had a friend who had his motorhome coated with bed liner (I have no idea which brand) and spent the rest of the time he owned the RV chasing leaks that were NOW almost impossible to locate. Anyone that does this needs to be absolutely SURE they have no leaks when the coating is applied. Also be sure you get a product that has color choice. He put black on his RV which turned it into an oven YOu can kiss any roof warranty goodbye also so not a great idea with TPO or Rubber.
Padlin
W. Ma.
Maybe they are talking this.
Happy Motoring
Bob & Deb
W Ma.
12 F150 HD SCAB EcoBoost LB 4x4
06 Starcraft 18SB
danskool
Elma, N.Y.
Wouldn't flexing cause cracks? Rhino isn't flexible is it?
Dan
2005 Crossroads Cruiser 27RL
2001 F250 XLT 7.3 PSD
Huntindog
phoenix arizona USA
I think the wieght of 8# per galon would be less when the liquid has evaporated from it.
I know that the Inyati bed liner that I had sprayed in my last trucks bed was pretty flexible. The bed and wheelwell sustained some pretty good dents from loads and the liner just conformed to the new shape.
Done right, this is a interesting idea. Done wrong, it could be a nightmare.
Not sure that it would be any more cost effective though.
Huntindog
2010 Palomino Sabre 30BHDS
TWO bathrooms...No waiting!
MICHELIN XPS RIBS LRE
2011 Silverado Big Dually 3500 4x4 CC D/A
EQUALIZER Hitch
100% BOONDOCKING
Check out Rusty and her pups at www.bluecollarbrittanys.com
