RV.Net Open Roads Forum: Travel Trailers: rhino roof? really?
 > rhino roof? really?
Wills250psd
walnutcove NC
Posted: 04/01/12 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
danskool wrote:
Wouldn't flexing cause cracks? Rhino isn't flexible is it?
Rhino is the most flexible bed liner on the market, and if aplied correctly it should be leak free for years. it adhears to about anything.
mikeb9550
MI
Posted: 04/01/12 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
Well, I dont think much would be gained since most of the leaks come from vents and AC which if you put bed liner around them, you would never be able to replace them. The AC has a gasket and no caulking. I personally would like to see TT companies have a one piece alum roof with molded lips for vents and AC where water cant in.
Me, I will just stick to the regular stuff. When it needs to be replaced, I will just do it myself.
Mike
2006 Ford E350 Van (standard length)
V10, 3.73, 5 Star Tuner, Hellwig Rear Sway Bar, Prodigy BC, Hensley Arrow Hitch
2006 Jayco Jay Flight 26BHS
E&J push'n wind
San Diego CA, The best climate on earth!
Posted: 04/01/12 08:27pm Link  |  Quote  |  Print  |  Notify Moderator
There is a place right here in San Diego that does it. I've seen their comercial and it looks like a pretty good idea. Have no idea what it would cost but I've got an idea to give em a call on it.
San Diego RV Center
Wisdom is the right use of knowledge. To know is not to be wise. Many men know much, and are all the greater fools for it. There is no fool so great a fool as a knowing fool. But to know how to use knowledge is to have wisdom.
Charles Haddon Spurgeon
cool beans
virginia
Posted: 04/01/12 09:43pm Link  |  Quote  |  Print  |  Notify Moderator
that stuff is almost bomb proof.literally,ask the mythbusters.
Artemus Gordon
Redding California
Posted: 04/01/12 10:50pm Link  |  Quote  |  Print  |  Notify Moderator
Had front of my Komfort shot with Rhino a few months ago. Even sprayed the propane tank cover. Very happy with results. Easy to clean and paint color matches. I went with the coating instead of "diamond plate" because it matches better with my high gloss gell coat. It has protected well, against stray rocks kicked up by my dually. Roof application should work fine in my opinion.
2012 Montana 3750 Hickory Edition, 2013 Ford F450 Crew Cab 4x4 Platinum options
2012 3750 Montana
Generator Box
danskool
Elma, N.Y.
Posted: 04/02/12 04:49pm Link  |  Quote  |  Print  |  Notify Moderator
Can we get the cost of that. Maybe a picture? I am interested, Good idea
Dan
2005 Crossroads Cruiser 27RL
2001 F250 XLT 7.3 PSD
vandave
jamestown, ohio
Posted: 04/02/12 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
There is a Rhino dealer in Columbus, Ohio that does it. They have a picture of one of the MH they did. They are sending me a quote for a 30' TT but I'm a long way from taking that jump. Rhino linings have been around for years and you would think it would be a real buzz if it was that good and cost effective. I think the $$$ will be the show stopper. JMHO
Vanda and Dave Ludwig (Vandave) Spoiled King Charles Spaniel, Ultra spoiled Cock-a-phoo, '12 2500HD, 4WD, CC, SB, 6.0, 4.10, 30U Arctic Fox, Equalizer.
Artemus Gordon
Redding California
Posted: 04/02/12 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
I assume you ment me? If not here is photo links anyway. About $300 to $350.00 for Rhino coating. Had the areas with marks sanded out and new gel coat first. ( did not have to but I am that way)..
Rhino Coated Front Cap
danskool
Elma, N.Y.
Posted: 04/03/12 03:48pm Link  |  Quote  |  Print  |  Notify Moderator
Yup.. That looks sweet. NICE JOB !.. Looks like money well spent.. I like it. My front nose on the 5vr has sun faded logos and and stone chips. I will have to find someone local to do that..
How well does it clean up after black streaking being a texture finish?
Thanks for the pics.
Golden_HVAC
Fulltime, CA, USA
Posted: 04/06/12 01:31am Link  |  Quote  |  Print  |  Notify Moderator
gbopp wrote:
JIMNLIN wrote:
I asked my a local truck and stuff type dealer about his spray on Rhino material on a large 8" x 20'-30'+ RVs roof. He gave me this deer in the headlight stare and made several comments. His first comment was why would anyone want to add that much more weight to the RVs roof. His second comment was "your kiddin' right".
Did he say how much actual weight the Rhino material would add?
Many vehicles are coated with Rino Liner, and it is not that heavy.
I have heard of Line -X used as a coating too.
I was quoted about $4,000 to clean my roof, coat it with Rino liner, and I did not like that price, I have a 30' Bounder. I guess they price it like a pickup bed, so much per square foot, and there is a lot more than 2 pickup bed's worth of square footage up there!
I coated mine with 4 gallons of Herculiner bedliner, it is white. Each container is about 8 or 9 pounds and my guess is over 1/2 the weight will evaporate as the product cures. Some of the Zyelene soaks into the EPDM, and the chemical smell does get inside the RV, so ventilate it well, and don't plan on taking a trip the next weekend, though I lived in my RV the night that I coated the roof, with the windows open.
The Herculiner is very flexible, I used a old coffee cup to dip out cups of the stuff and pour onto the roof. When done, the coffee cup was coated with about 1/8" thick coating of herculiner, and I was able to remove it in one piece, still have it, never took a picture of it yet. The stuff can tear, but I was able to get it off without tearing it up much. Yes it is still flexible 1 year later.
If you look in DIY, you can find my post about the bedliner on the roof, with pictures.
Fred.
